Question about RCA TruFlat 27F520T 27" TV
Red picture My tv is red tinted and the writing is all red, The tv is only a year old, nothing has happened to it like being dropped or anything. I just had a new cable box hooked up to it.
  • RCA Master
  • 12,061 Answers
Hi, looks like a "Shop" job to me... ask for a "Quote" B4 ya proceede. If it's a CRT screen then ya have "Lost" one or more of ya colour "Guns" if LCD then the Driver circuitry has gone faulty. Either way it's not an easy fix.. for a home job.
Posted on Jul 31, 2007
SOURCE:
Picture has red tint
I would unplug it from the wall for a while and see if that will help reset it. Also make sure there are no magnetic devices near the screen because this will change the screen color as well. Mine will mess up every once in a while so I just unplug it while I am off running errands, plug it back up when I come home and it seems to reset itself. Good luck
Jun 15, 2014 | Emerson EWF2004 20" TV
Red tint on PROTON TV picture
did u go through the menu and check for the contrast and tints?
Mar 03, 2012 | Proton NT-333 31" TV
My tv sceen has a stain that makes anything white look yellow.
The color image is comprised of three colors, Red, Green, and Blue.
All the other colors are mixtures of those colors. The yellow picture indicates that your set is lacking sufficient blue drive.
First of all check to make sure that the tint control is not misadjusted.
The next thing is dependent upon the age of your television. If it's an older set that yellow tint is a sign of an aging picture tube.
If it's a newer set, less than 5 years old, have it analyzed by a electronics technician that is familiar with televisions if he is skilled enough he will know right away if it's the picture tube or not.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 [email protected]
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Toshiba 32AF41 Power up Problem and Green Screen
My first inclination would be to check the picture tube, especially if the set is over 7 years old. If it is not that, then anything from bad solder connections to capacitors or a defective IC could be the cause. If it's over 10 years old, replace it. No use flogging a dead horse.
Jan 13, 2007 | Toshiba 32AF41 32" TV
Blurry Screen
ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Nov 13, 2006 | Jensen TS2750J TV
RCA TruFlat  27F520T 27" TV Logo
83 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
