Question about Maytag MER5775Q Electric Kitchen Range
Getting E1 and F1 or F7 on my Maytag Advanced Cooking System
Please help, I can not locate my manual...it is approx 7 years old! Thank You for time and trouble!
  • billunotti Mar 06, 2009
    after using cleaning mode door will not unlock and f1 appears on readout
F1 shows on panel and fan is running, how do i turn this off - what does f1 mean?
Posted on Jan 12, 2010
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
I have about and 8 year old maytag advanced cooking system. how do i use the self clean feature. i know its not just hitting the clean button
you should have a set clean time on your timer..if it allows set for 4 hours..maybe auto...
then close door and lock
Dec 19, 2010 | Maytag Ovens
Maytag advanced cooking system manual MER5775Q, how to resolve a F9 error message and also get rid of the "lock" notice
Hi stuartwri190,
Kindly check the door latch components. The F9 fault code is about the door latch.
Hope it helps.
Thank you for using FixYa.
Aug 15, 2010 | Maytag MER5775Q Electric Kitchen Range
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F2-E0 Shorted Keypad Replace Keypad
Ovens with 2 Digit Displays
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
MAYTAG oven flashing f1 and f7?
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 21, 2008 | Maytag MER6772 Gemini Electric Kitchen...
I attempted to locate a user's manual for you but your model number came back as invalid, please recheck your model number, and follow the link that I provided. This will allow you to download a manual for your range.
http://www.managemyhome.com/mmh/products/ManualSearch.action
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Jun 17, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag electric range shows F1 error message and beeps what does this mean? and now it permanently shows this message and not thee closk
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 03, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
1,247 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
