Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Axiss washer front door seal replacement
How does it get replaced? Is it glued?
Need to know how to remove old seal and what I need to do for installation. I have the seal but just need a "how to" guide.
Thanks
  • 112 Answers
Remove the top of the machine(screws are at the back).
Look down the side of the front door on the inside of the machine.
You will see a metal wire band holding the rubber on.
You usually only need a screwdriver to loosen the screw which holds it tight.
Try it out and get back to me if you get problems
good luck
Posted on Jan 31, 2009
  • Bosch Master
  • 744 Answers
This video will show you how to replace the Bosch Axiss washing machine door seal with step by step guide on the process of how to fit and replace
Posted on Jul 20, 2013
Water leaks apparently from a tear in the circular seal next to the door
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 17, 2011 | Bosch WAS20160UC Front Load Washer
I need help replacing the front door gasket and seal
Bosch WFMC3200 Front Load Washer replacing the front door gasket and seal.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all
Sep 12, 2010 | Bosch WFMC 3200 Front Load Washer
I n eed to find a scamatic for my washer
This video will show you how to change a door seal on this Bosch Nexxt Premium WFMC6400UC front loader washing machine
Jul 08, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
The door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
shaun
Mar 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Replace door gasket
It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
Plz rate this solution .
Thanks.
Dec 19, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch washer
This video will show you how to change a door seal on this bosch
Jul 06, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
418 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
