Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Black sutt coming out of heater covering the house
I come home from a deployment and black sutt is on everything and it is coming from my gass logs.
  • heatguy May 11, 2010
    if you are sooting on gas fireplace and it is ventless shut it down it could be producing carbon monoxide.if it is vented and sooting check that vent is clear and open if you have soot all over this also can be producing carbon monoxide which can be deadly call a pro
  • 188 Answers
This can happen when your logs are not in the correct position. This also can happen if you are burning candles, a smoker, or spraying aerosols. I would have a Professional check it out.
Posted on Jul 08, 2009
Hi there my home is about 3 years old. i have noteced black dust on the doors window frames basically everywhere. i don't know why.
Does this unit have an blower? If so there is no filter and this can happen.
Direct vent means no open flame in the house but you might still have a combustion problem. Open the front cover and check for black soot. Also check outside at the flue for soot. If so then you need to get this thing checked. Also make sure the little door for the pilot is closed. May have a improper install here if only 3-years.
Sep 05, 2011 | Empire DV-215 Direct Vent Natural Gas...
The fan on my dashboard is not working. I am thinking of replacing it with a used one from a junk yard except I dont know where is located.
it's behind the glove box. here are procedures from autozone.com:
CAUTION The Supplemental Inflatable Restraint (SIR) system must be disarmed before removing the blower motor assembly. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
  • Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
Remove the glove box from the instrument panel.
Fig. The blower motor is located behind the glovebox, behind the blower motor cover
  • Remove the A/C-heater blower motor cover.
  • Disconnect the blower motor wiring connector.
  • Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
Remove the blower motor mounting screws.
Fig. Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
Fig. The blower motor is secured to the housing with three small screws
Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
  1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
  2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
  3. Reconnect the blower motor electrical connector.
  4. Install the A/C-heater blower motor cover.
  5. Install the glove box into the instrument panel.
  6. Reconnect the negative battery cable. Check blower motor operation.
Oct 15, 2010 | 2003 Dodge Caravan
What causes black soot to smoke up our complete house with ventless logs
Take the pilot and burnner assembly all apart and blow it out with compressed air then reassemble and make sure that the air shutter is totally open. The soot is cause by a bad air/fuel misture that is too rich and cause carbon to form from incomplete combustion. If the burner continues to make soot then reduce the gas pressure to the gas log at the pressure regulator.
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 24, 2010 | Empire DV-215 Direct Vent Natural Gas...
How to replace a heater fan motor, is it changeable from the engine compartment?
No, but it isn't too hard to get to under dash. I will paste instructions from autozone.com below. Pictures may not come thru.
Front Blower Motor
See Figures 1, 2 and 3
Fig. Fig. 1: The blower motor is located behind the glovebox, behind the blower motor cover
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
Fig. Fig. 2: Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
Fig. Fig. 3: The blower motor is secured to the housing with three small screws
  1. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
Sep 15, 2010 | 1999 Chrysler Town & Country
My Reliance water heater high temp shut-off keeps tripping.
YOUR WATER HEATER ME BE IN DCS OR PANAL SYSTE\M SO YOUR THREMOCOPL GIV YOU WRONAG TEMPRATURE SO YOUR WATER
HEATER SUTT DOWN
Mar 06, 2010 | Water Heaters
Have there been any unexplained air bag deployment in 2005 santa fe on the drivers side while in motion. my husband was driving and he said the air bag deployed and then he hit a car in front of him. do...
http://www.nhtsa.dot.gov/cars/problems/ is the website I checked for your car and found no reference to this issue. There are reports of airbag deployments with no collisions, although they are rare. The computer in your car is capable of displaying the deployment, and may show which sensor in the front if any caused it to deploy (collision first/deployment second) or if no sensor signal (deployment first / collision second) is logged. Whatever the outcome, you will need a specialist in data extraction to achieve this.
Jan 06, 2010 | 2005 Hyundai Santa Fe
How to remove a heater blower motor on a 2004 Dodge Caravan.
Please don"t forget to rate:
Removal & Installation
  1. Remove the A/C-heater blower motor cover.
  2. Disconnect the blower motor wiring connector.
  3. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  4. Remove the blower motor mounting screws.
To install:
Jan 04, 2010 | 2004 Chrysler Voyager
How to replace a heater core in a 1994 chevy 1500
As with all vehicles it seems the first part that they build around is the heater core. It is under the dash above the floor housed in a black plastic sealed box. Sealed with goop. Locate that box and start removing everything around it that is peventing taking the cover off. Of course disconnect the heater hoses under the hood a thefirewall.
Warning it is never as easy as it sounds.
Nov 29, 2009 | 1999 Chevrolet Silverado 1500
Natural gas heater
The burners are shot. The heavy metal tubes with the holes that the burner flame comes out of, has burnt through. Instead of little rows of holes, there is at least one large hole in it. Unless someone has changed the gas>air mixture, you need new burners.
Mar 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
103 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
