Question about Apple Mini IPod
Apple mini mac 1.8, won't allow access to "system preferences"
Using mini mac and seperate hardrive and DAC (digital-analog converter) for music system thru ITunes. can hear downloaded music playing thru mini mac, but won't play thru stereo system. I need to know how I can get to "system preferences "
  • 34 Answers
Apple Menu/System Preferences/Sound
Posted on Aug 28, 2009
  • 600 Answers
In the dock /grey square with cog icon is system prefs, rhs of line 2 is sound
Posted on Aug 13, 2009
4 Suggested Answers
  • 13433 Answers
SOURCE: 80 gig ipod won't play music?
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If that all that didnt work, then i suggest you contact apple or your dealer for more assistance or repairs.
If you need more asistance, let me know. Good luck.
Posted on Mar 23, 2008
  • 4 Answers
SOURCE: ipod not recognized by computer or itunes
I had the same problem. The problem ended up being with Itunes not working right. The solution I found was to download the program winamp and download the plugin for apple ipod. Then you can sync and add software thru winamp. After syncing one time it even worked with itunes but I like winamp better, so I synch all music using winamp.
Posted on Oct 23, 2008
  • 10 Answers
SOURCE: Computer Won't Recognize
Hi. Maybe your computer doesn't recognise your iPod, because it doesn't have the driver installed. Your iPod Shuffle looks like one of the newer types, which are smaller and lighter than the previous version. Try re-installing the driver from the Apple website, but make sure it's the correct one, or you might damage it.
Posted on Jan 04, 2009
How many Dac in 3010 yamaha receiver
What exactly do you mean by DAC (Digital-analog converter)?
As the audio core of this receiver is digital, it has an ADC for each analog input. Then it has one DAC for each analog output, so it has 13x DAC for Pre-out (11.2ch which are used also as inputs to amplified speaker outputs) + 2x DAC for stereo AV out + 2x DAC for stereo headphones.
Nov 09, 2014 | Yamaha RX-A3010BL Aventage 9.2-Channel A/V...
How do I connect my MacBookPro to my I Mac to transfer photos and music?
  1. Connect the Thunderbolt cable to the Thunderbolt ports on each computer.
  2. OR
  3. Connect the Mini DisplayPort cable to the ports on each computer.
  4. To change display settings, choose Apple menu > System Preferences, then click Displays on the primary Mac.
Oct 03, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
NAD WIRELESS USB DAC 1 KILLS WIFI CONNECTION
The NAD wireless using the 2.4Ghz frequency which is also used for WIFI.
Your option would be to change the channel of your WIFI to see if you can reduce the interference.
Your best option is to use 5Ghz for your WIFI (this requires that your Wireless router and Laptop support 5Ghz).
Jan 31, 2014 | NAD DAC 1 Wireless USB digital-to-analog...
Bluedio super mini
Go to the menu bar at the top of the screen and locate the Bluetooth utility. Link with the device and you can access it just like any other drive, Transfer your files. Itunes may be able to do this for you. Otherwise go to system preferences, locate bluetooth and follow the same procedure.
Jan 03, 2014 | Apple Computers & Internet
HOW DO I LOAD MUSIC ON MY BLUEDIO HEADSET FROM MY MINI MAC
Hey Ronald!
To be able to load music onto your Bluetooth Headset, you're going to first want to connect the headset with your Mac! To do this use the following steps:
Step 1: Click on the Apple logo in the upper left of the Mac, then choose System Preferences. Inside of System Preferences, choose Bluetooth.
Step 2: This screen should show a list of Bluetooth devices connected. Make sure the "Bluetooth is Turned On" on the Mac. You can toggle it on the left side. Make sure the Headset is currently turned off.
Step 3: Once the Headset is turned off and the Bluetooth on the Mac is turned on, turn on your Bluetooth Headset to place it into Discovery Mode. Keep an eye on your Devices list because once it appears, select it from this list.
Step 4: After it's been chosen from this list, you will now have it as an Output Audio device. You can always double check this in System Preferences in the Sounds section, on the Output tab.
Next, we want to be able to play music through that Bluetooth Headset. Go ahead and open up iTunes or try playing a video on the Mac Mini to ensure the audio is received!
I have linked two articles from the Apple Support website which may offer some additional assistance:
OS Mavericks Use Bluetooth headset with your computer
http://support.apple.com/kb/ht3563
Good Luck!
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
SCREEN MOVES WHEN THE CURSOR MOVES ON A MAC MINI. HOW DO I SOLVE THIS PLEASE? THANKS YOU
This means you have screen zoom turned on. To turn it off, press Option - Command - 8.
Alternatively, hold down Control and scroll down on your mouse's scroll wheel.
Nov 19, 2009 | Apple Mac mini G4 Desktop
Analog / Digital stations
Hello mikekahan,
OK you are not going to like this but here we go any way. First of all I need to explain how your channels are created.
When the RF signals come into the headend of the Down converters they are separated into pre channelized designations DC (Down Converter) 4 Stream 1 (DC 4-1, DC 4-2...) now once this is done the down converter signal is fed into a channel processor which takes the incoming signal from the Down Converter remodulates it and puts it on an assigned channel 4-1 could become channel 4, 4-2 could become channel 5 and so on. Once this is done you end up with your regular channel line up for analog channels, now for digital its a little different you have IRDs (Integrated Receiver Decoders) which take the off air or satellite Digital RF signals and convert them into MPEG Streams which is the fed into what is called a SEM (Motorola Architecture) Stream Encryption Module which assigns numeric designations to the MPEG streams and then converts the MPEG streams back into RF. Now at this point we have analog and digital signals what then has to happen is the the analog signals must be turned into MPEG streams to go through the system so what happens is from the channel processor the analog signal is put into a SE (Stream encryptor) Like the SE1010. This takes the analog stream and turns it into am MPEG stream and feeds it into the SEM also and the SEM assigns a numeric designation just like the digital signal and this can sometime follow the same numeric designations as was obtained from the Down Converter, So what you end up with is analog and digital signals having the 4-1, 4-2, 5-1, 5-2, ..... format. This is where other equipment comes into play These designations are then kept in a database and are matched to their proper channels by use of the DAC and RADD along with an IPG server. These allow the SEM to assign true channel designations to the converted channels, now the SEM DAC, and RADD talks to your STB, this is way the channels are correct because the SEM and the DAC/RADD are matching what is on the IPG (Interactive Program Guide). When you remove your cable box the tuner in your TV does not know how to deal with the DAC, RADD and IPG signals so it only displays the RF information which is the 4-1, 4-2, 5-1, 5-2 data.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 27, 2009 | RCA 20F424T 20" TV
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Apple Mini IPod Logo
107 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
