Question about Canon Pixma iP6000D InkJet Photo Printer
Paper will not feed correctly
The paper seems to be pulling to the right and then getting jammed. I have tried to see if there was any paper is stuck but can not find any. Could it be that the rollers need replacing? If so, where would one have that done?
  • Jackie Simon
    Jackie Simon Jan 31, 2009
    did not resolve issue. It seems rollers are not working correctly-where do you go to get a printer fixed?
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 31, 2009
  • Anand Kumar
    Anand Kumar Jan 31, 2009
    This hard ware problem you need to get the rollers service if the printer is under warranty please get it done the by the company or out of warranty get it service at printer service point....
    Good luck...
SOURCE: paper feed skews right and jams
Cheap printer, barely worth the cost and trouble of new feed wheels even if installed by the user!
Posted on Feb 03, 2008
SOURCE: paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Posted on Nov 14, 2008
APremkumar
  • 564 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
Posted on May 26, 2009
  • 27 Answers
SOURCE: hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Posted on Aug 10, 2009
  • 20 Answers
SOURCE: paper wont feed
I had the same problem and it turns out one of my kids put a coin into the top of it and it was far down inside where i could not see it.and it was stuck in the bend of the paper feed after tearing it almost all the way down i finally was able to see it removed the coin and it worked.
Posted on Nov 03, 2009
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper jam. paper pulls towards the right hand side and jams
    Sound like you have something stuck in the paper feed path, check for a paperclip or similar, it may be that you have had a jam and torn off a piece of paper inside the printer which is now stuck, when removing jams from any nmachine allways pull paper in direction of feed never back on itself as it can cause this very problem
    Dec 03, 2009 | Dell 810 All-In-One InkJet Printer
    HP Photosmart C6280 Will not feed paper correctly
    Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
    Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jul 03, 2009 | HP Photosmart C6280 Printer
    Paper pulls to the right, jams, won't print, tried different paper still won't print
    Sounds like the feed rollers need cleaning.
    Clean the feed rollers, lint free cloth,bottled water.
    wait for them to properly dry
    Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
    Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
    Check paper size is correct in print properties too.
    Should be good then
    Try print.
    Regards
    Richard.
    Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Printer 2480- my printer is pulling paper only on right side
    Try this :
    3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
    Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
    Printer will not feed paper correctly
    there were may situation that can help with this trouble,
    1- try to see if the trays are seated correctly no bend or twisted
    2- try to check the quality of your paper no concave nor convex ( like U or N)
    3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
    4- ensure no hindrance on the paper path inside the machine
    5- reset the unit once more
    let me know if you need some more
    Jul 25, 2008 | Office Equipment & Supplies
    Canon i9950 feed issues
    Apr 26, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
    Printer pulling on paper
    My husband took the top cover off the printer and took a good look inside with a flashlight. He found a hot pink crayon stuck where the paper feeds through. I guess I should have had a better look initially, since the paper never made it all the way through the printer. Works like a charm now!!
    Feb 23, 2007 | Lexmark X6150 All-In-One InkJet Printer
    Canon Pixma iP6000D InkJet Photo Printer Logo
    148 people viewed this question
    old marine
    old marine
