Question about Lanzar VIBE286 Car Audio Amplifier
My amp turns on and pumps once then it stops bt the amp is still geting power
The amp turns on and starts to play then it stops and the protection led turns on. i replaced all my fuses and checked the wiring and it is still doing that
    Novelist:
  • 77 Answers
First try unhooking the speakers and see if it continues to go into protect mode. If it does'nt then your speakers are running to low of ohms required for that amp causing it to go into protect mode. If it still goes into protect mode check your ground, might have a voltage problem and check voltage going into amp. I have read the manual and this amp has advanced circuit protection. So if all I have asked you to do and it still goes into protect mode then amp is faulty and has some output transistors shorted or power supply mosfets shorted. Let me know what you find. But you need to do what I have explained to narrow the problem down. Good luck, Keep me informed. I will be glad to help you thru this. I also have a business of repairing car amps and you will not find anyone cheeper. So if you want it repaired and you feel you can't do it, just send it to me and I will repair. If you decide this E-mail me at:skinnman33@gmail.com and we can discuss it in more detail. Just a thought to try and help you out. I have many customers that send me there amps and I repair them and ship them back. A few come from this site. Let me know
Posted on Feb 12, 2009
Dhd amp has power but blue leds flash once and turn off. the led in the back lights up green but the blue leds that light up in the front flashon once, and then turn off. it won't let me sub hit.
Dhd amplifierDisconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Feb 05, 2015 | Audio Players & Recorders
How to configure
For Bluetooth,pull Aux cable out,turn on power at rear of unit,then hold down the power button for several seconds until the LEDs start flashing blue/red.Turn on BT on the sending device and scan for other devices. When the blue/red stops flashing,they are paired.Hit Connect on your phone and it's good to go.
Sep 27, 2014 | Video Cameras
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Whenever I start playing on my xbox or playstation, the receiver will shut off (the red light is blinking around the power button). Once I hit the button, it stops and then I can turn the receiver back...
does it only shut off on high volume or a loud noise?
It's the amp tripping to protect itself.
look out for a shorting speaker wire or faulty speaker etc. disconnect each in turn to find out which
Sep 03, 2010 | Denon AVR-987 Receiver
Hi, i geting problem in inkjet printer connon
These are the instructions which worked for me on my Canon pixma ip470 bought August 08:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.
Jan 08, 2010 | Canon Pixma iP4500 InkJet Printer
Amp wont stay powered on as soon as bass hits in goes into pm
The amp is not geting enough current.You need to use some larger gauge cable and it would probably be best to add a small power capacitor.If your not familiar with a cap then stop by your local car audio store or google it and you will get a lot of imfo.
Sep 06, 2009 | Sony XM-2165GTX Car Audio Amplifier
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
if you change amps and it goes on protection the speakers are blown causing the amp to protect try changing speakers
Mar 24, 2008 | Car Audio & Video
Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
Driving in first gear
Your Amp is in protect. Disconnect your subs and turn it back on. IF the led goes back to green the you have a blown Sub and it will need to be replaced. If the amp stays in protect even with the subs removed the the amp is toast.
May 29, 2007 | MA Audio HK2000D Car Audio Amplifier
Lanzar VIBE286 Car Audio Amplifier Logo
164 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
