Question about Onkyo TX-SR605 Receiver
The volume control on the Verizon remote won't work on my fios TV
Eveything else works.
  • Anonymous Mar 11, 2009
    I have a Verizon Fios Tv Remote control and the volume doesn't work but everything else does.
5 Suggested Answers
SOURCE: Code for Verizon FIOS remote Control
i have a konika television set and i can not get it to turn on or off with the verizon remote. I went through the booklet and it said to press the >> unitl the television set went off but, I pressed it until the end of the list and it never shut off. what can i do?
Posted on Apr 05, 2008
  • 3422 Answers
SOURCE: 1988 KAWASHO TV: Need remote control codes for VERIZON FIOS Remote Control
Th ebst solution to get your problem is to contact them HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 07, 2008
SOURCE: FiOS TV remote control
bought an new one for $5.
Posted on Jun 30, 2008
SOURCE: verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Posted on Mar 28, 2010
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Posted on Oct 31, 2010
CaRC not working on my vsx823
With some of these elaborate setups, the receiver overrides your settings and connections to configure a default arrangement for certain functions. The rationale for this is often buried obscurely in the equipment instructions. You may have to resort to trial and error, connect and disconnect to get a satisfactory result.
Dec 01, 2013 | Pioneer Vsx-821-k Receiver
You may want to try a different universal remote, like the Logitech Harmony.
Apr 07, 2008 | Onkyo TX-SR605 Receiver
Verizon fios remote codes for samsung receiver
Feb 20, 2010 | Samsung Audio Players & Recorders
Volume control
This is an option that is generally available from your TV set. Sony, Sanyo and others have it. It may be called differently by its owner, but it's most likey available from your TV's menu settings.
One probable name could be AVC (Auto Volume Control). Good luck!
Aug 17, 2009 | Yamaha RX-V690 Receiver
Hook up vizio tv to fios box
Run HDMI from FIOS to TV directly, then run Digital coaxial or optical to the cbl/sat audio input of your receiver. That's it. If you have any more questions, just post a comment and I can help more.
Aug 08, 2009 | Pioneer VSX-D509S Receiver
Need to program fios remote for Dynex 26 lcd
i looked on verizon for you try the dynex website
Dec 06, 2008 | Onkyo TX-SR605 Receiver
Onkyo htr 330 universal remote codes
I have the HT-R570 Receiver and here's what I ended up doing to use the Verizon FIOS DVR remote to turn the receiver on and off with volume control. Know that Onkyo uses 2 codes 1 for on and 1 for off so use the AUX for ON with Volume control and the DVD for OFF. (I rarely use my DVD and when I do I use the DVD remote that came with the DVD)
Use the AUX and codes 1347 or 1558 to turn the receiver on with volume control. Press AUX and OK together and release. Enter the code. it should now turn the receiver ON with volume control.
To use the DVD button to turn the Receiver OFF, you have to use the search method to capture the code. Tried every code I could find on the internet and their is no universal code for OFF and ON.) With the receiver ON, push down DVD and OK together and release (should get 2 flashes of all component keys) enter 922 and with remote pointing at the receiver press the >" (forward/pause button) then press and release the >> (fast forward button) until the receiver turns off. If you go too fast and go past it, quickly turn receiver back on (within 20 seconds) and press-release the <<(backwards button) slowly until it turns off again. Then press the OK button to store the OFF code in the DVD function button. Any questions...E-Mail me at MrBlueOcean@verizon.net Lots of Luck!
Nov 30, 2008 | Onkyo HTR500 Receiver
Jun 28, 2008 | Onkyo TX-SR605 Receiver
Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Mar 28, 2008 | Pioneer Audio Players & Recorders
Oct 24, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
565 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
