Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
The back filter and cover blow off immed when vacuum turnd on
My Kenmore 23612 progressive...the back filter and the cover blows off as soon as I turn on the machine. There is alot of air flowing out of there. I have replaced the filter thinking it's because it's dirty and time to change. It still blows off!. Waddup?
  • Irwin Fletcher
    Irwin Fletcher Dec 22, 2016
    I have one doing the exact same thing; I can put the filter and cover back in place but as soon as I turn the vacuum back on the filter cover begins to come out and if I move the vacuum at all the cover and filter fall out everytime
  • 2,186 Answers
Has the cover got tabs that is suppose to catch when it's installed? check and see if there are broken plastic ends either on the vac or cover. It should be able to catch to hold it on.
Posted on Dec 22, 2016
SOURCE: blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Posted on Aug 10, 2007
  • 184 Answers
SOURCE: kenmore Progressive 25614 vacuum
check the reset button on the brush assembly which is also called the power mate. if not then take it to your local sears repair center. if it is the pc board. sears has them in stock. I think it is about $7 for the part.
Posted on Feb 05, 2008
reddevil6
  • 1673 Answers
SOURCE: Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
Posted on Jun 01, 2008
  • 10 Answers
SOURCE: Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Posted on Jan 14, 2009
  • 22 Answers
SOURCE: kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Posted on Feb 10, 2009
Power is on and running but there is no suction at all and peformance light is on
did you check to see if it was stopped up something could be clogged in the hose. carefully Try running a broom handle or stick throught the hose making sure there is nothing like a dirt clog in there. also if you have a filter you can clean it out because this will cause the vacuum not to have any suction I just take mine outside and put it in a plastic bag and bang it on the ground a few time to get all the dirt out. I also use an air compressor to blow out the filter every once in a while.
Nov 12, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
How do you get the cover off the vacuum so i can have access to the motor?
If you are trying to get to the motor and not the bag Sears repair people have a special tool to remove the rubber seal and if you try it your self you will end uo ruining it or stretching it and if it does go back together when your done it wont seal properly and therefore it wont have sufficient air flow.
Oct 07, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
My miele vacuum cleaner hose has no suction
have you tried changing your filters.? Also using genuine filters gives you much better suction
Feb 14, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
I can't seem to get the belt cover off of my Kenmore Progressive 400. There are two buttons that say above "belt and bulb change" but the buttons do not move. Do you know how I can remove so I can put a...
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
My dyson animal 14 roller stopped spinning!!! help!
remove base cover on foot and check for hair buildup. remove, re-assemble and test. of not it is probably either broken belt /drive vane and will require shop service
Sep 13, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Which side should face me (black or white) when I put in the CF-1 replacement filter?
The white side is filter media and the black side charcoal. The black side should be the side that the air flows out of and the white the side that the air flows into.
Jul 18, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Back filter and its door blows off as soon as I turn it on.
thats good has good suction i guess there should be a cover on that back filter if you can't find you can tape it down leave air coming out
Jan 31, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Need new power brush
Get the number off the power head, it should be on the bottom, then go to Sears.com, click on the parts link, put in the complete model number, a parts list will come up and you can order your part.
Jan 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
102 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
