Question about Dell Latitude D800 Notebook
Dell latitude d800 not booting
Hi
my problem is when i switch on nothing comes on i see the lights blinking for a split second but nothing else changed the power adaptor
with one i know is working still the same
would be greatfull with any help
recom55@hotmail.com
  • recom55 Jan 31, 2009
    Hi again
    did what you said no joy, when i plug in the adapter there is no indication of any power going to it in other words there is no charging light on there is a green light on both adapters i tried i know both adapters are working fine
    thanks again
    recom55@hotmail.com
  • recom55 Feb 01, 2009
    Hi
    i finally got it to switch on , and got this error code obstruction the air flow from the system fan vents
    call dell support with this error code m1004, i stripped down the laptop cleaned the fan which had little or no dirt around it, repasted the cpu ,updated the bios still the same problem,also if i try to switch on with the battery installed it will not switch on, remove the battery and it will come on with the same error press f1 to cont and it will run normal i reinstalled the battery with the laptop on and it is fully charged five green lights on test i had only 2 green lights so it is charging ok, just fitted the battery again and unplugged the power adapter laptop running ok, until i switch off i have to remove battery for it to come on again, mind boggling.
    thanks for your reply
    recom55@hotmail.com
  • 679 Answers
Did you try removing all power source (battery and the main connection) and then putting it back on?
and also check the processer fan might be the fan is not working so, the laptop off after some sec.
Posted on Jan 31, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, How old is the Laptop? How did the problem start off?
I doubt if the motherboard is dead, else you should see at least the startup screen.
Try this: Remove the battery and try to start the system while power is connected.
    Sergeant:
  • 250 Answers
Remove the battery from its back by removing the latch from its back and reinsert it again and check out.
  • 916 Answers
Unplug the AC adapter, remove the battery and wait for 1-2 minutes. After that plug the AC adapter ans try starting the laptop again. Sometimes this trick helps.
It also could be a memory related problem. Try reseating the memory module, just remove it from the slot on the motherboard and install it back. Try installing the memory module into the other slot (if it’s available). If you have two memory modules installed, try removing them one by one and start the laptop just with one memory module installed.
  • machadojr_fe Jan 31, 2009
    If you are getting no power from the adapters but you know the adapters are fine the problem could either be from the battery or the adapter input port. Try another battery and if that does not work you will need to repair the port.
  • machadojr_fe Feb 01, 2009
    Having to remove the battery and then plug in to charge and reinsert the battery is a problem with the battery itself. You will need to replace it in order for that problem to go away.
I Have a Dell Latitude D800 and it's plugged into power. when i hit the start button it lights up a couple of lights on the keyboard, they go out after a couple of seconds and then nothing happens?
Is the battery charging? and is the power adaptor properly plugged in? If yes then it's probably a faulty PSU and you will need to phone DELL for a replacement/repair.
Sep 06, 2010 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Dell latitude D520 will not start up
The board not holding power,
this can be first chk the RAM press it tight.
the next is chk smps output.
Aug 17, 2009 | Dell Latitude D800 Notebook
Beep noise during booting and no keyboard response
Sounds like the key is stuck. You will have to remove the keypad to check the switch underneath.
Mar 14, 2009 | Dell Latitude D800 Notebook
Cpu upgrade latitude d800
what do the Lock Lights indicate (Flashing , ON, ON perchance) it appears that the CPU is either not compatible or bad. Have you tried the original porcessor?
Jan 29, 2009 | Dell Latitude D800 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
Apr 21, 2008 | Dell Latitude D600 Notebook
Latitude D800 wont boot
ok now it sounds to me the power pack on the back has shat its self so ufourtanetly u need a new one if u still have a valid warrenty ring dell or go to their web site at www.dell.com and they will happiley help u there number is also their but if u dont have warrenty go to their website and see how much it costs for a new battery but see a friend who has a dell laptop and plug in the power cord it might be your power cord not your com or battery so give it a wirl and if u have any problems email me at mid.nightclub@hotmail.com
Dec 31, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
54 people viewed this question
Alun Cox
