Question about HP Color LaserJet 2600n Printer
HP 2600, magenta 2mm to left misaligned - HP Color LaserJet 2600n Printer
Just had almost exactly the same issue - except the Magenta was printing 2mm below where it should have been.
Went through all the recalibration menus multiple times and the factory restore etc. Then wondered about the toner cartridge. If the problem is just with the Magenta, maybe this is where the issue lies. The printer had remanufactured toners in it - all the others were fine. Went and found a new HP original magenta toner - printer did its default recalibration on startup and the config test page came out like new. Put the old one back in and problem reappeared.
Strongly suggest you try another toner cartridge - as I suspect the chip is to blame in some way.
HTH.
Crazy Coconut.
Posted on May 22, 2009
HP 2600 is not distributing magenta evenly leaving red to orange
If you are getting orange mean magenta cartridge working well, better once check all cartridge health condition..
Aug 22, 2014 | HP Photosmart 2610 All-In-One InkJet...
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
HP 2605dn Black prints 1/8" offset to left. Colors do register
Missalignment problems ae not uncommon with this series of printer.
The cause is one of the sensors (which are used for calibration and alignment) on the transfer belt, is faulty.
These sensors are NOT availale, and replacement of the transfer belt is the solution.
Transfer belt replacement on these printers requires quite a bit of dismantling, its not considered to be a user replacable consumable.
Hp 2600
try cleaning magenta's laser.
Aug 14, 2009 | HP Color LaserJet 2600n Printer
HP Q2612A Cartiridge refilling
YouTube - Toner Refill for HP Cartridges 2600, 3600, 3800 etc
Jul 08, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
MAGENTA TONER IS FADED
try to calibrate your printer. also try to change your drum unit.
Jul 08, 2008 | HP Color LaserJet 2600n Printer
HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Oct 07, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
481 people viewed this question
Ben Johnson
