Question about Refrigerators
Refrigerator not cooling
We put extra ice cubes on the ice maker. Leter the ice melted and the refrigerator/freezer quit cooling. Now it has a bad odor. The make/model # is Whirlpool ED25RFXFW01.
  • 296 Answers
Can you hear a fan behind the fridg working?
If not then the condesor cooling fan has quit working and is easy to replace. (this cools the coolant down before its enters back to the pump.
Can you hear a fan inside the fridg and freezer?
If not the the cooling coil fan has quit working and is easy to replace. (this blows on the coils and were the cold air comes from.
If all of the above is fine. Then the compressor is bad or it has leaked freon.
Being that there is a bad odor that is a sign of a burnt up fan motor or compressor.
Posted on Jan 31, 2009
  • James Bradburn
    James Bradburn Jan 31, 2009
    If you find it to be a fan then i can help guide you through replacement. If its the compressor then if the fridg is not new its not worth replacing.
    To access the inside fan let me know if you need help gaining access.
  • Refrigerators Master
  • 8,220 Answers
Clean out the dust and lint from the coils under the ice box. make sure the fan motor blade is turning. Check the back wall of the freezer for frost.Remove the compressor relay and give it a shake. If it sounds like a salt shaker it is bad, if it makes no noise it is bad, You should hear and feel the floating start switch. let me know
  • Dan Webster
    Dan Webster Feb 08, 2009
    Refrigerator dead: it may be that the defrost timer has went into
    defrost and got hung up there. Twist the timer around several times and
    it may start working till you can get another.
    Refrigerator runs all the time: The thermostat is fried (internal contacts stuck together) replace it.
    Compressor won't run: burned up relay. Remove the relay from the
    compressor and shake it. If small particles come out or it sounds like
    a salt shaker or there is no sound at all or it smells and looks burned
    then it is bad. Replace it.
    Freezer getting warmer freshfood not cool at all: Check under the
    bottom for the fan motor to be running and the cob webs, dust, dirt,
    and pet hair, off the condenser coils. If the fan underneath has quit
    then the ice box won't get cold.
    Everything is freezing over in the bottom and the top. Bad cold control.
    Do I need freon? 99% of the time NO. Most of the time it is a
    dirty coils problem or a bad fan motor, unless you have a leak. Since
    the ice box only holds 4 ounces of freon it would quit cooling at all
    in a short time if it had a leak.Their would be no halfway cooling, not
    for long anyway.
  • Dan Webster
    Remove your ice maker if the mold is staying hot.
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Why would my ice maker start freezing all my ice cubes together?
ice maker made cubes, but you shouldn't put in freezer any warm staff, its melt ice for while after freezing them together
Jul 29, 2014 | Jenn-Air Jenn Air Refrigerator Replacement...
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
After replacing ice maker assembly, ice is not getting made?
Ice maker is leaking water and causing the ice to freeze?
Ice maker is noisy and not making ice?
Refrigerator ice maker stopped making ice?
Ice maker leaks water into ice bin causing a glob of ice?
Amana Refrigerator leaking water from ice maker?
Ice maker leaking?
Ice maker is dumping the ice cubes out before frozen solid.
Water overflowing ice maker?
Ice cube is getting stuck up hard in ice maker
Icemaker quit working?
Quit making ice
Water leaking into ice tray, frozen glob of ice
Not making ice, and water leaking in freezer?
The ice maker stopped making ice?
Ice maker not making ice?
Ice maker quit working?
Ice maker dispensing black pieces of plastic in the ice?
Replaced Ice maker but its still not making ice?
Ice maker leaked creating an ice block?
Ice tray leaked?
Ice maker stopped functioning?
Ice maker stop working?
Ice maker failed
Old ice maker stopped working?
Old ice maker started leaking?
Ice maker not working?
Ice maker overfills and cause water to flow into ice dispenser and freezes?
Ice maker didn't make ice?
Ice maker was leaking?
Ice maker was leaking after it filled up with water?
These will help.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Freezer is working, fridge is not cooling, currently at about 58*. Ice maker is not hooked up, but appeared turned on.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
The refrigerator is not working
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
Jul 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
