Question about XION II Mercury (XON102) ATX Mid-Tower Case
I purchased a zion 2 case and I cant figure out the fan plugs because the plugs are like the ones use for cd burners to power themup
  • 28 Answers
To connect the power cable, just take the 4-pin connector coming from the fan and connect it to any 4 pin connector coming from the power supply. you can then use the 4-pin connector to power a cd/ dvd drive or ATA hard drive
~gnomer
Posted on Feb 01, 2009
I have no manual for my memorex lightscribe. I purchased it an never used it so I might have lost a cord or something. I need to know if I only need one USB plug or do I need some other one too? I have...
Most DVD burners require a power cable as well as a USB cable. Check the slots on the back to be sure, check for any holes that are round with a pin in the middle, or possibly three different holes in some cases. If you see a slot like that, you need your power cable.
May 04, 2011 | Lite On LightScribe (HP640VI) (HP640VI)...
I recently bought a used TEAC CDWE552-GB CD Burner for my old computer. I received the power cord and cable to power it up but not the cables to attach it to my computer ( HP Pavilion 4550Z ). The ports on...
Unfortunately, I don't think you can use this CD writer on the HP Pavilion 4550Z directly. The CDWE552-G is an external USB device. The HP Pavilion 4550Z doesn't have any USB ports.
There are two options that I think you could consider. 1) Get a USB card to insert into the micro-tower. It's currently easier to find PCI USB 2.0 cards, see https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100168119%20600022008 for some examples. Before purchasing, check to make sure the card is compatible with the OS on the HP Pavilion 4550Z. It started with Windows 98. You will have to remove the Fax/modem to use that slot. (An ISA card might work but I haven't seen an ISA bus USB card in years.)
2) Take the CD writer out of the external case. The CDWE552 should use an IDE cable; just swap this CD writer for the one in the micro-tower. The HP Pavilion 4550Z should have the appropriate cables inside the tower. The original CD reader specifications indicate it was an IDE device.
I hope this helps.
Nov 29, 2017 | Computers & Internet
Hi , my mail request ID is WTM201101251546565307. I am unable to play CD/DVD after inserting them into laptop/netbook even though i have plug the two USB into the usb ports. i keep hearing sounds...
There is a large chance your laptop/netbook does not provide adequate power to properly power the unit, this is the case in 80% of netbooks/laptops and portable PC's. The only way through this is to purchase a USB WALL POWER CABLE or USB AC Adapter, then can be purchased anywhere from $2.00 to the higher end ones for $19.99 with all the bell's, whistles and additional outlets, you can find them on AMAZON.COM or BUY.COM or anywhere.
Hope that helps, you will see the use and this is the future of power units, USB is the future of power, and USB requires no voltage and less conductivity to produce power. Safe, low required power for the world!!! LOL!! It is how it is people!
Jan 25, 2011 | ASUS SDRW-08D2S-U/BLK/G 8X Slim External...
How do I use a 7 disk duplicator tower? Model 52X65x52x
Hi you put your dvd or cd into the top copier,put however many blanks you want copied into the burners below, you dont have to use all 7 if you dont want to make sure the control panal on the front says copy press enter and thats it.
Jan 24, 2011 | Tower CD&DVD Duplicator Cases: 8 Bays...
Which connections do I use to hook it up?
When you break into the computer (disconnected from power, please), the sockets on the back of the burner will only fit a couple of plugs (power and data) - just inspect it closely, don't force the data plug as it goes in only one way. Same for the power plug. Some burners have a little two conductor small plug that hooks up to some sound cards. In most cases you can leave this off if you don't have instructions with your burner. Good luck.
Nov 25, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
Reading disks but wont burn them
The only "help" is to purchase a new "internal" CD-writer, disassemble the casing, remove the "dead" CD-writer, insert the new one, and reassemble the casing.
Nov 05, 2009 | Micro Solutions Backpack Burner
Fan
Your motherboard has quite a few little three pin white plugs on it, look closely and you will see them on the motherboard. These are auxillary fan plugs and power all the extra fans you can install in your case. Just attach the plug from the fan into one of these sockets. They only go in one way.
Oct 10, 2009 | RaidMax Sagitta
Dvd drive
Sounds like you purchased a SATA drive when you need a IDE drive...or vise versa. Check the box. If that's the case, just exchange the drive for the proper one.
Jun 01, 2008 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
How do i install a second writable disk drive???
aloha...this can be done, IF your computer has the expansion capacity. what kind of computer are you using?
Mar 17, 2008 | AOpen : CDRW 52x32x52 Beige Color Retail...
CD BURNER REMOVALE
in first step you should bee off the power cable from plug
now you can open your case cover and remove the cd burner,
open the case cover for anther pc or pc what you wont install cd burner,
install the cd burner and close cover case'
play your new pc with cd burner .don't forget power cable and data cable for cd burner (it's same the old one)
Dec 16, 2007 | Compaq Deskpro 2000 PC Desktop
XION II Mercury (XON102) ATX Mid-Tower Case Logo
138 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
Farokh Merek
Farokh Merek
JonSnell Electronic
JonSnell Electronic
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
