Question about NEC SuperScript 870 Laser Printer
My NEC 870 laser printer has paper jam. How can I fix it?
  • 3 Answers
Open the top printer door by pressing the round release button on the left side of the printer. Remove the toner cartridge (numbered 2) and the photoconductor cartridge (numbered 1) from the printer. This will give you full access to the paper path and you should be able to remove the jammed paper. If you pull on it and it begins to tear or is feels like it is caught on something, remove the paper and paper tray from the front of the printer and try to reach and remove the jammed paper pulling it back out the direction it went in.
With the jam removed, replace the paper tray and paper, re-install the photoconductor (#1) and the toner cartridge (#2) into the printer and close the top door. Make sure you get the door closed firmly and that it catches otherwise you will still have an error light and not be able to print.
That should fix your problem... good luck! :-)
Posted on Dec 20, 2009
You could try use the Windows XP SuperScript 870 driver or you could install the HP LaserJet III printer driver. It should work with your printer, but may have limited functionality.
Feb 08, 2010 | NEC SuperScript 870 Laser Printer
Both power light and paper jam light on
clear the paper jam. take out the paper(if any) from back of the printer. Clear all prints in que and try to print
Aug 13, 2008 | HP DeskJet 970cxi InkJet Printer
My printer won't work with my computer
You can download the driver here:
Be sure to unplug the printer from the PC before installing the driver.
Feb 22, 2008 | NEC SuperScript 870 Laser Printer
Vista problems with NEC SuperScript 870
If you load the printer drivers from a Windows XP install disk (in the i386 directory), that worked for me.
Prints what looks to be bar code
I have the same problem. I have replaced both toner and photoconductor, did not solve the problem. I have been using XP for some time before my printer started acting up.
Feb 21, 2008 | NEC SuperScript 870 Laser Printer
Order supplies
go to and type in toner cartridge and the model number. I'd be astonished if you didn't see dozens of em.
got backup for your computer?
Feb 19, 2008 | NEC SuperScript 870 Laser Printer
Superscript 860
If you can reach the sheet, you may apply a lot of force on in without the risk of destroying the printer.
Jan 13, 2008 | NEC SuperScript 860 Laser Printer
NEC SuperScript 870 Printer
First open your Control Panel and click Printers. Now click “Add a Printer”. Specify if you printer is Local (plugged in to your computer) or on the Network (plugged in to a different computer). We are assuming you have a Local printer.
Next specify the port. Usually you can just take the default here. Now you will be presented with a list of available printer drivers with manufacturers on the left and printer models on the right.
Under manufacturers choose “HP”. Then on the right scroll down and find the “HP LaserJet IIP”. It will probably show up just after the “Laserjet IIIP”. Click next and follow the instructions to complet installing your printer.
Aug 13, 2007 | NEC SuperScript 870 Laser Printer
No response, all lights on panel are on
Try uninstalling and reinstalling the driver software and cross your fingers with hope that unit is now recognized by your OS.
Apr 24, 2017 | NEC SuperScript 870 Laser Printer
NEC SuperScript 870 Laser Printer Logo
235 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
