Question about LG WM-1832C Front Load Washer
Washing Machine Odours
My LG Tromm has a lot of musty odours that are transfering into my clothes. How do I eliminate the odours?
The solution to this terrible problem is actually quite simple. First, do not close washer door between loads. I know this is a pain but this is the real source of your problem. Unlike top loaders where water is not able to spill out of the lid, the doors on front loaders are gasket sealed. This means that moisture is unable to escape and dry out between loads (unless you leave your door open!). To remove the musty smell, run an empty load with two full scoops of Tang Instant Breakfast Drink or a powdered lemonade mix. This may need to be done several times at first. In the warmer months you may want to do this monthly as a preventative. Also, be sure to get clothes out of the washer promptly. If they sit in the washer with the door closed for several hours you will be back where you started with the musty odors. Good luck!
Posted on Jan 14, 2008
  • LG Master
  • 12,061 Answers
There is a product called "Nilodour" a very concentrated liquid.. that elliminates smells etc, ya put a few drops into an empty wash (ie only water) cycle and flush.
Posted on Jul 31, 2007
SOURCE:
How do I get my clothes to SMELL like clean clothes? Darn washing machine stinks them up!
Check the drain where ti empties into, smell the drain thats most likely where the odour is coming from.
Aug 18, 2014 | Maytag Centennial MTW5800TW Top Load...
Smelly washing machine and washed clothes
This is usually because of a bacteria build up on the machine. Suggested actions: Remove and thoroughly clean the soap tray. Remove the waste pipe from the drain pipe you have it poked into and ensure that all is clean and emptied. If your machine has a filter (Usually behind a 4 inch square door on the front towards the bottom of the machine if one is fitted - this depends on the machine and I'm sorry, I'm not familiar with your madel). Finally, take 2 or 3 DISHWASHER TABLETS put them in the machine's drum and wash at the highest temperature that your machine will allow. Modern biological washing powder uses bacteria to break down and "eat" stains. Bacteria creates unpleasant odours. Dish Washer tablets and powder is designed to kill bacteria. Hope this helps
May 12, 2010 | Washing Machines
LG leaking from bottom, Not the filter clean-out.
Not necessary to blame LG, ALL of these front loaders are garbage. They were designed poorly and released too soon just to have a new gimmick.
Jan 16, 2010 | LG WM2688HWM TROMM SteamWasher
Musty/Mildew smelling clothes...
lg has a known problem with smelly mildew cloths. If you call LG they will tell you its not there problem. Cheapest solution is to wash door gasket with some clorox and then betwen washes leave door open. On the washing supply shelves there is a product you put in the washing machine run a wash without cloths and it does the same thing except it costs $7.If you bought it a t Lowes go back and ***** to store manager my friend did exactly that and got the machinje replaced
Sep 30, 2009 | LG WM2688HWM TROMM SteamWasher
Odour
Throw a dish towel and a cup full of baking soda in to a 'small load'. Run it through the first wash cycle but turn off before it hits 'Spin' or 'Rinse'.
Repeat several times.
This should get rid of most odours. If no joy, repeat the process using bleach or vinegar instead of (NOT combined with) the baking soda.
Sep 05, 2009 | Kenmore Washing Machines
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Same problem with our LG Tromm
I had the same problem with my LG Tromm and was ready to throw away every one of my towels they were so rank smelling. As a last resort I filled the detergent area with one cup of white vinegar and ran a load through on hot. Then I washed them with just a tablespoon at most of detergent. They came out smelling fine, the mildew smell was completely gone. How long it will last, I don't know.
I also read somewhere recently that we all use way too much detergent in our washers and dishwashers. And surprise, surprise, the post went on to say that too much detergent in your towels/clothes can leave a musty, mildewy smell in them.
Now when I do laundry, no matter what it is, I use about 1/4 of the amount of detergent called for, even though the HE uses so much less. In all, maybe 1-2 Tbsp, and everything comes out just as clean.
Also, try using a product from Clorox just for front loading washing machines. It's Clorox Washing Machine cleaner...it seemed to help with the overall smell. And I agree, I will never buy this particular machine again.
Aug 10, 2009 | LG WM2688HWM TROMM SteamWasher
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
LG Tromm Steam Washer
How do you have your drain hooked up?
I have seen people stuff the pipe so far into the stand pipe that when it goes into drain it siphons the water back. The water doesn't go all the way into the unit, but enough that the water in the 'P' trap moves, gas can then come up from the sewer. Make sure your drain pipe is hooked up properly. It should also not be a sealed fit either.
Sgt 48
May 08, 2008 | LG WM2688HWM TROMM SteamWasher
LG WM-1832C Front Load Washer Logo
243 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
