Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Back filter and its door blows off as soon as I turn it on.
The rectanglular changeable filter located in the back of the canister vacuum near where the cord comes out from. This practically explodes open and blows out the filter. A tremendous amount of air flow comes out of there. Waddup?
  • raewmt Feb 12, 2009
    The filter door is there, it gets blown off as well as the filter itself. On the door it says to not operate the machine without the filter. Oh well. Thanks anyway :)
  • 547 Answers
Thats good has good suction i guess there should be a cover on that back filter if you can't find you can tape it down leave air coming out
Posted on Feb 12, 2009
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum has lost suction and is making a hissing noise
I had the same problem with my Kompressor.Initially I had cleaned all three removable filters.There is two in the canister that can be washed with dish soap. The HEPA filter is located in a compartment on the lower front side of the vacuum.This HEPA filter should not be washed.I found that tapping it inside a trash can dislodged alot of dust from it. After cleaning all the filters and canister I was having the same hissing noise coming from a small hole near the bottom of the vacuum. Next I removed a hose fitting on the lower back of the vacuum and that is where I found a very large amount of debris clogging up the hose. I used a metal coat
Nov 11, 2011 | LG Kompressor Upright Vertical Cyclone...
Need a picture or specs of the insides near motor
the big paper fiter attaches to the underside of the big black top piece of vacuum. there is a round plate and a nut you scew on to hold it. a foam rubber filter fits over it.
May 17, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
My shop vac blows dust as soon as it's turned on and throughout use. I have changed filters, nothing is helping. What part of my vac can not get wet, or is there a better way to clean out the system?
there should be a cover or sock over the filter,this will stop the dust.the paper filter is the part that can not get wet. if you don't have a cover for your filter use an old sock or something simular to a sock.
Aug 04, 2009 | Shop Vac 584-04-00 Quiet Canister Wet/Dry...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The back filter and cover blow off immed when vacuum turnd on
Has the cover got tabs that is suppose to catch when it's installed? check and see if there are broken plastic ends either on the vac or cover. It should be able to catch to hold it on.
Jan 31, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Electrolux vacuum turning off
hi take off canister cover remove bag now if you look inside canister you will/should see a gauze type filter at the opposite end of canister from where bag locks in ?? remove this gauze filter and for now just shake tap on floor to remve dust/debri etc /from it this gauze is the filter that when vac is working andfilling the dust bag ? the pressure of air only that blows bag up but allows only air to pass thro the microscopic holes in bag ? then has to expel via the gauze filter to exterior ? and any dust etc that is clever enough to seep through the bag ??? will not pass further due to gauze ? and so prevents this blowing back into room ok so far ?? if this gauze is blocked due to whatever ?? then pressure build up in canister will result in cover lifting? this is provided that the fault is not the actual cover securing latch is ok and not damaged ? hope this explains and helps ? best wishes from uk !
Nov 08, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
77 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
