Question about DeLonghi Alicia EMK6 Coffee Maker
DeLonghi Alicia EMK6 - H20 error
I've had this coffee machine since Xmas 2006 and it's always worked perfectly. Problem appeared yesterday when trying to make my secind coffee of the day: I click on the start button, it lights up for a few seconds and then displays "H20" error Of course the machine is full of water etc. Any advice would be greatly appreciated.
  • Renato Pia Aug 02, 2007
    Have descaled as instructed but it's been no use at all. Any further advice?
  • Renato Pia Aug 06, 2007
    Thanks but still no luck. Opening the bottom base is easy I guess, but what do I look for?
  • 944 Answers
Here is the link to the instruction manual if you need it; http://www.delonghi.co.uk/pdf_files/EMK6.pdf There is no information regarding this error message available online, but I think you are right and it relates to water - probably the sensor of the water level is stuck/blocked/scaled up. you can try descaling using white vinegar 50/50 solution with water, leave it overnight. Give the whole unit a good shake, in case the level sensor is a mechanical float device and it is stuck. See if any change. You can call Delonghi/Comet from this link; http://www.delonghi.co.uk/service_info.php hopefully they will tell you for certain what the error message means - if they do and it is different from what is discussed above, then please ask again if you want to try and solve the problem yourself. Hope this helps :)
Posted on Jul 31, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Aug 02, 2007
    Check there are no switches that tell the machine if the lids/covers etc are closed - if so then try pushing them in manually if you can and see if the error message goes away.
    Try unplugging the machine for at least half an hour, see if it resets itself. If not, try holding down the power button when you plug it back in.
    If no joy from that then either you will need to open the machine up and we can try and talk you through what to check (a digital camera can help), but i would try and contact DeLonghi first to see what they have to say.
    I suspect a faulty heating element, which is not too hard to verify if you have access to a multimeter. Other possibility is a faulty control circuit board, which is probably repairable and definitely replaceable - ask DeLonghi if they will supply parts if you want to go that route - else we can most likely source the parts from the individual manufacturers using the info printed on the parts themselves.
    Let me know what you would like to do :)
LED display not working
if the lighting is LCD then there could be problems with the internal components of the screen. should get it checked out
Dec 07, 2013 | Saeco Syntia Espresso Machine & Coffee...
Vtech sit to stand dancing tower stopped working
Not a solution but ours has done the same. Annoying!
Jan 03, 2013 | Vtech V Tech Sit To Stand Dancing Tower
Yesterday, my Keurig was giving me trouble with the menu, but it still made my coffee. That was the first time my coffee machine has ever given me trouble over the nearly year and a half I've owned it....
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Jul 05, 2011 | Keurig Elite B40 Coffee Maker
Display message - brewunit block - can not undo to start the machine Miele CVA 620 Build-in Automatic coffee machine
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Jan 13, 2010 | Miele CVA615 Espresso Machine
My Xmas gift sewing machine worked perfect stitching for about 18" than all of a sudden an F8 message occured and the machine kept making a clicking noise.
you should put an oil to the needle bar of your machine and to your bobbin. always put an oil if they clicking noise again.
Dec 26, 2009 | Brother CS6000i Computerized Sewing...
Saeco Royal=,beans do not appear to be grinding, machine whirs for 30 seconds then says add beans have tried 2 different types beans after cleaning bean hopper works first 2 coffees ok then stops
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Oct 02, 2009 | Saeco Royal Professional Espresso Machine
Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Dec 24, 2008 | Nespresso Aeroccino Automatic Milk Frother
DeLonghi Alicia EMK6 Coffee Maker Logo
2,749 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
