Question about Thetford Norcold RV Cooler/Freezer
My freezer is not freezing anything
I noticed that everything in my freezer was defrostingand i dont know why. i tried switching to the gas and that is not working either.
  • 373 Answers
Try this
revome everything around it
and clean around the grill opening
at bottom
Posted on Jan 31, 2009
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
My freezer doesn't seem to be freezing as well as it has in the past. somethings are frozen hard but ice cream isn't as solid as it should be
Try this... unplug...
take everything out and defrost the freezer
(go get a couple bags of ice and a big clean garbage can so you can keep the food cold)
you can defrost the freezer faster with a hair dryer
when you finish turn t'stat to high setting... put all food back in and dont overload and dont block any air vents (if they are located at top dont overlaod)
plugg in wait 24 hrs...
if you dont notice a difference let me know...
hope this was helpful
Mar 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Try removing everything out of your fridge, switch it off and open all doors for 12 hrs. Then close doors and switch it on for another 24 hrs before putting in you stuff. most likely the evaporator is iced up, you need to defrost if fully.
May 04, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Fridge problem
is this a frost free fridge if so then it is possibly not defrostingand has built up to much ice in the evaperator
cheers grantsreps
Sep 29, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Freezer is over-freezing
the possible cause is the temperature sensor or thermostat is not working, maybe its switch is stuck up on ON position, it looks like a wire attached to the area where ice is building up, it is connected to a switch to turn off the compressor thus controlling the operation of your freezer. replace with new thermostat will solve the prob.
Aug 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Thetford Norcold RV Cooler/Freezer Logo
211 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
