Question about Frigidaire GLER642A Electric Dryer
Heating element Whats the easiest way to take out the drum
  • Frigidaire Master
  • 8,220 Answers
1. pop the top
2. remove the front
3. remove rear access panel, get belt off motor
4. remove drum retainer(where applicable)
5. grab belt at top of drum, using belt as handle, yank it straight up off the rear bearing mount( do not remove the screws inside the drum)
Posted on Jan 31, 2009
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: changing heating element
No need to buy the whole pan. The replacement coil is way less. 5300622032
Very easy dryer to repair. Start by popping the top and then removing the front. Get te drum out and remove the heater assembly. Remove the old coil. NOTE: when replacing the new coil be vewy vewy careful not to stretch the coil too much as this causes a hot spot and shortens the life of the coil considerably as in like one load maybe. LOL.
db4f97d.jpg.
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
How do I remove a Samsung Dryer DV4006 heating element
You will NOT have to remove the drum, as the previous poster said. Unplug the dryer (VERY IMPORTANT). Undo the screws for the cover at the top right at the back of the dryer. Your element is here. Detach it from the cover plate. The undo the bottom cover plate so you can access the plug where the element attaches. You will need to reach in and manipulate the wire out of the clips (easy).
To put it back, just reverse what I've said.
Mar 10, 2010 | Dryers
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
Changing heating element
db4f97d.jpg.
Jan 31, 2009 | Frigidaire GLER642A Electric Dryer
The dryer won't heat up
Check the thermo fusenormally located behind the back panel on the rear plate on the back of the drum second assumeing that the fuse is ok check the element located on the other side of the same plate that has the fuse this is assumeing that it is a standard dryer you can first test the element with your multi meter with out removeing the plate by disconnecting the wires attached to the element the easiest
being on continuaty and listen for the beep if no beep element is blown.If you need more indepth info let me know and I will see what we can do,Please remember do not undertake any repair unless the machine is off and unplugged.
Jan 26, 2009 | Kenmore 72822Gas Dryer
I Have an indesit WG 1185 B - WG 1185 - W and a piece of wire has got under the rubber seal and in under the drum. You can hear it scraping along the drum when in use and after using it a couple of times...
The easiest way to remove objects from between the drums is to remove the heating element. To do this remove the backplate from the machine. the element is located on the back of the drum and is rectangular shape with curved corners and will be secured by a single nut in the centre. To remove it unscrew the nut and pull the element out, usually the wire will be wrapped around the element, be careful not to damage the rubber seal and make sure the machine is unplugged before attempting. if you need any more help please let me know.
Thanks,
Nov 24, 2008 | Indesit Washing Machines
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Nov 01, 2008 | Dryers
Bra wire stuck in drum, not visable to the eye, how do i remove the drum paddle to remove the wire?
easiest way is to remove the heating element and the gap between the tub and drum will be exposed and you can fish it out.
moral - don't wear bras with wires!!
Jun 29, 2008 | Washing Machines
Frigidaire GLER642A Electric Dryer Logo
90 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
