Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Ipod shuffle, Xm reciever, Fm modulator
Why can't a Ipod shuffle with the 3.5mm female audio out plug into my Delphi FM modulator and work through my reciever like the XM does?
Delphi reciever, Delphi FM modulator. Does Delphi have something in the FM modulator that keeps any other product from working with it?
Thanks
    President:
  • 1,990 Answers
Yes it Does. The Ipod will not work in this Application. The FM Modulator is Programmed to Accept only Certain Connections. Please Rate My Response! Thanks!
Posted on Jan 31, 2009
Roady XT works fine on Boom Box/Will not transmit to car antenna/will not show "set frequency" on menu,,
Cannot have anything plugged into the audio output/audio jack, or it shuts off the FM Frequency modulator.
Sep 05, 2010 | Delphi Roady XT XM Radio Receiver
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi skyfi won't connect to my fm radio automatically.
The audio plug overrides the FM frequency setting. That way if you use a tape adapter to run the music through it will use that source instead.
A lot of FM channels are getting crowded into a lot of markets out there. The best way to fix the problem is to use a direct FM module. This way your Sirius will override the FM channel whether it is used or not.
Here is a link for one:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1998401&catParentID=7872&scId=7872&oldParentID=7872
they are very easy to install.
Mar 17, 2009 | Delphi SKYFi XM Radio Receiver
Static sound or no sound with FM Trans and with Audio Plug
I agree with you. It sounds like an internal audio circuit problem, especially if the tape adapter does the same thing. Have you tries headphones on the unit? If they work, then get the sure connect as it plugs into the headphone jack (Aux out jack)
By the way, you as an XM customer for years, usually XM will just give you another unit to keep you as a customer. I've seen it many times. Couldn't hurt to ask!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
XM Roady2 Built in FM Modulator not working
It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
Feb 01, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
148 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
