Question about Panasonic Viera TX-32LX70 32 in. LCD TV
How do I remove the stand from a panasonic tv. model TX - 32LXD70
We would like to remove the stand of a panasonic television model TX - 32LXD70 for it to be placed on the wall of our living room.
  • Anonymous Mar 26, 2014
    remove stand
  • 718 Answers
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Posted on Feb 17, 2009
Screw sizes for the 4 screws for the wall mounting plate
They are usually fine thread machine bolts, a call to Panasonic customer service with the correct model number will be the quick way to find out what you need, most will be readily available at places like Home Depot or any major hardware store.
Dec 21, 2012 | Panasonic TX-32LXD70 32 in. HD-Ready LCD...
How to remove a stand
you have 4 screews to remove on back of your tv. 2 each side of connector panel
Apr 29, 2010 | Televison & Video
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Panasonic lx-32lxd70 lcd tv not working in cyprus?!?!?!
Under the channel setup menu there should be a way to change the input type of the channel. When you go to edit a channel look for this setting. If all your channels are grainy this is probably the solution also.
Jun 15, 2009 | Panasonic TX-32LXD70 32 in. HD-Ready LCD...
Cant get the stand off a panasonic 32 inch TX 32LXD60 to put on the wall
TX 32LXd60
Lay the tv face down on a flat surface. Do not scratch the screen ! Use a cloth.
Remove the 4 screws above the stand. Pull stand out. Replace screws.
You can get Operating Instructions from;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
enter the model number- click search- and download the Operating Instructions . The Operating Instructions will illustrate the stand.
Apr 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
How to remove stand from panasonic tv model no tx-32 l m d 70
Place tv on its BACK,with the screw holes underneath.Remove the four screws,remove stand,and turn tv over to rest on the sceen (on top of a towel)or some other cloth so as not to damage the screen,and replace screws.The reason for placing the tv on its back when taking out the screws,is that,unless you have a magnetic screwdriver when removing the screws the are difficult to remove as they are deeply recessed.
Apr 09, 2009 | Emerson RP6248 AM/FM/TV Radio
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
5,364 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
