Question about Broan-NuTone Designer 721 Ceiling Fan
Bathroom fan looking at installing a broan model 744 bathroom fan...would like to know how you have to access the unit to service..im looking at installing on ceiling of my combination bath/shower unit. thank you Dan.
  • 37 Answers
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Posted on Jan 31, 2009
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
I purchased a Broan 744 light/fan combo. I want to wire the light and fan to separate switches. Do I use single pole switches and how do I wire up the switches?
Here is a link to the instruction manual. Page three shows a wiring diagram for separate switches.
http://www.centralvacuumstores.com/meta/pdfs/info/744NT+Installation+Guide.pdf
This is the Switch NuTone Broan recommends for that fan.
http://broan.com/display/router.asp?ProductID=2949
Nov 18, 2010 | Broan-NuTone N-763RLN Combination Light...
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Broan-NuTone Designer 721 Ceiling Fan Logo
359 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
