Question about AOpen MX46-533V (91.89U10.061) Motherboard
I am trying to connect the cables from the front panel
I am tryin to connect front panel cables i.e ... hddled power switch reset switch and so on. but i dont no where to put them all and cant find a diagram anywhere can you help please
  • swufabuda
    swufabuda May 11, 2010
    What brand and model is the motherboard and brand model of the case?
  • 565 Answers
Here ya go:
http://download.aopen.com.tw/userdownload_List.aspx?RecNo=3594&Model=255
Usually the connections are color coded.
Posted on Feb 01, 2009
Jumpersettings ex761 front panel
On the pins marked on the motherboard. The location on the motherboard varies from board to board. Your motherboard manual will show you. If you don't have a manual go to the board manufacturers website and look in the support section.
Feb 05, 2013 | AOpen XC Cube EX761 (95EX7692Z1) Barebone
I dont no to connect the front wires in mother board
The front wires are usually for power, hdd led. power button and reset button and sometimes extra usb ports and audio ports. All motherboards have a small section that has 8 to 10 grouped pins protruding that you can attach these wires to. The motherboard will diagrahm where the pins hsould go. For example the light for the hard drive wires are probably labeled "HDDLED" and there is two of them. One positive charge and and ground. On the motherboard, in the grouped pins there is a small label that goes:
''___'
'_____'
HDDLED
PWLED
It may look like this but in a different arrangement. What does this mean? Connect HDDLED to the top two pins. Doesn't matter which way the positive and ground go. And connect the power led PWLED to the bottom pins. Follow this for all the other labels.
Hope this helped.
Jul 05, 2011 | Computers & Internet
Idnt knw hw to cnnct power switch , hdd led ,speaker , reset.led+ , led- . pls help me by sorting out my problem.by full description . and photos of connecting cables.
''___'
'_____'
HDDLED
PWLED
I'm looking for the pinout for the FRONT PANEL
DX-5150 Illustrated Parts Map Refer to Page-2 for Complete Motherboard Connections and Description
Actual Image of the Motherboard (Rotate it 90 Degree Clock-wise for a better view)
(The above illustration is at Page-2 of the Manual)
Please download the Manual and the Motherboard photo from the above links and make the Front Pannel Connections.
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | HP Computers & Internet
I have a Dell Inspiron 546 running Windows Vista. When turning it on the Start button lights up, but the display very quickly goes into power saving mode. Nothing further can be done. The computer or...
Hi. Were you able to see the the DELL post screen when you turn on the computer? Take out the battery and unplugged the power adapter from your computer and to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn on the computer.
Nov 07, 2010 | Dell Inspiron 546 MT Desktop Computer
Chaintech manual MPM 800-3
What kind of chipset have you got on the board
All intel boards have a standard key
SPWR/PWR - PWRLED .... Open
RST HDDLED .....SPK
Jun 08, 2010 | Chaintech MPM800-3 Motherboard
Theirs no indication where about to put the power switch,power led,reset switch and HDD led in motherboard acer veriton 3600g?
The connections are printed on the edge of the MoBo under the pins. With the back panel on your left the front panel connector pins are on the bottom right bottom row should be (from left to right) PWRLED PWRSW
The row above HDDLED RSSW
Apr 09, 2010 | Acer Veriton 3600 (V3600GT00150) PC...
Front panel motherboard samsung harappa-30 PBA:BA59-00905A
i wont to sound drivers for polaris motherbrod
Jun 12, 2009 | Computers & Internet
Power switch notworking ( ASUS P4PE-X Motherboard)
Please refer your motherboard manual and fix the front panel cable including power button. After this if power button is not working than swap the power button cable and reset button cable.
And then start your PC by pressing the reset button.
Else you just recheck all the cable + RAM + CPU.
Mar 09, 2009 | ASUS P4PE-X Motherboard
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Aug 28, 2007 | Systemax Ascent PC Desktop
AOpen MX46-533V (91.89U10.061) Motherboard Logo
173 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
