Question about DEI Python 1400XP Remote Start/Keyless Entry System
Car keeps stalling
I just got the remote car starter installed in my vehicle on January 13, 2009 and it seems like everytime I try to start it for the first time of the day it keeps stalling. I called Circuit City who I had install it and of course they told me to take it somewhere else to get it looked at. Any ideas what might be causing this?
  • 2 more comments
  • cvranka Jan 31, 2009
    It just barely starts and then it shuts right back off
  • cvranka Feb 28, 2009
    It is a 2006 Chevy Trailblazer
  • Allison Hulbert May 11, 2010
    how long does it run before it stalls
  • Anonymous Mar 19, 2014
    when using the remote start to start it stalls the vehicle out
    Problem Solver:
  • 5 Answers
I need to know what kind of car do you have
Posted on Feb 27, 2009
You might try going into the menu and increasing the start time.
Posted on Mar 22, 2009
Why after driving my 2006 528i bmw say about 30 to 40 min when I turn the car off and try to start the car up again it will not start. but if I wait about an half hour the car starts right up
I believe the 5 series has the same IVM module.
2006 BMW 750i - IVM module - Replaced on 5th January, 2015
Car would no longer recognize remote starter key and I could not start the car. Lights on in dash, but no noise, no starting.
Inittially thought one of my remotes were no longer good, then thought maybe it was because I had my iphone too close to the key..... None of my initial diagnostics were right, it was the IVM module. I often waited 15 minutes, then it started; then finally one day it wouldn't start at all.
Apparently the Integrated Voltage Module (IVM) has a relay in it that fails over time. The car began intermittently not recognizing the Remote (key), then failed completely. Replaced the IVM module and the car started immediatly and has started everytime since replacement. Part cost $127.US + tax at BMW dealer or $80. on line. Pretty cheap for what it has (9 connectors, a printed circuit control board, several relays and multiple fuses). Easy to replace and it took 1/2 hour to replace and is located under passenger side cabin filter (under the hood) on the 750i - there are nine (9) connectors to remove and re-install on this module. Mine was an original part Manufactured on 21 January, 2005. Tools needed: one Allen wrench and a # 10 socket. See YouTube for video.
Apparently Dealer will replace for close to $500. You can do it yourself.
Hope this helps!
Feb 05, 2015 | BMW Cars & Trucks
2006 Polo Classic engine doesn't cut out when key is turned
this means you have feed back going into the ignition circuit or power flowing have you installed a remote start? to find out which circuits are causing the issue pull one fuse out at a time when the car keeps running this will give you a starting point it could be a stuck relay to wires melted together make sure the key is off when pulling the fuses
Sep 03, 2012 | 2006 Volkswagen Polo Classic
I just had a Viper VSS4000 installed in my 2011 Camry. The car has a smart key system, so everytime I open the door when the car is remote started, the engine shuts off and I have to turn on the car with...
Sorry, there is no take over feature available for the 2011 Camry considering that all doors must be closed to perform the remote starter sequence.
Mar 10, 2011 | Remote Start System
I have a problem with my avital 4103 remote starter everytime i try to start try to start my car my car alarm goes off
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Feb 24, 2011 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Car starts then stalls I have installed a Pretige remote car starter on My 2005 Cadillac Escalade EXT. I have the bypass installed with the key in it. The truck starts then stalls. Any answers?
You have the wrong bypass. The bypass you are using is for universal transponders. You need the Passlock 2 bypass. The passlock is a resistance that is read from your ignition cylinder by the bcm that will allow your truck to start.
Jan 20, 2011 | APS-901 Prestige Remote Start
Car Stall or won't start even after fuel filter and pump replaced
I am almost positive that the cause of the problem is with the remote start. After maket remote starts are not the best idea because they have to splice into the factory wiring and alot of times it has a bad effect on the car. you should definatly look into getting the company that put it in to fix the problem
Feb 02, 2010 | 1993 Oldsmobile Cutlass Supreme
I own a 2002 Toyota Rav 4 - 5 speed, when I purchased it I had a remote car starter installed and it worked great until now. If I use my car starter and I stall my car out it will not start again for about...
You either have a bad remote starter, or the remote starter has caused the body computer to fail. Remove the remote starter completely from the car. See if the car starts normally. If not, the body computer has failed. This is a very expensive item, and have been found to malfunction due to remote starter electrical failures.
Nov 10, 2009 | 2002 Toyota RAV4
While starting the car with a audiovox remote starter the car starts up and runs about a second and shuts off and tries to restart and once again it stalls other wise when you start the manually the car...
all remote start alarms must see that the engine is running usually from a coil sense wire this is obviously not connected as your alarm keeps trying to restart
Sep 20, 2009 | Vehicle Parts & Accessories
Car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Dec 16, 2008 | DEI Valet Keyless Entry System
My vehicle dies everytime I turn it off...
how old is your battery,have you tried a new one?Sometimes a really stuffed battery also interferes with the ECU,and can result in switching things on and off.
Dec 15, 2008 | 1994 Mercury Grand Marquis
DEI Python 1400XP Remote Start/Keyless Entry System Logo
239 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
