Question about Proscan 32LA30Q Television
Horizontal line I have a scrolling horizontal line and I can not figure out how to tune the channels
    Sergeant:
    Champion:
  • 289 Answers
Just use this right(->)arrow and left(<-)arrow to tune the channels.
thanks..
Posted on Jan 31, 2009
Switched from cable to satellite via hdmi cable. Now there are scrolling jagged horizontal lines and no audio.
try running the auto tune program in the set as what you describe may be out of tune for the stations
Sep 05, 2015 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Screen is black no sound either what should i do?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
Aug 22, 2015 | Televison & Video
I just bought a 2004 Cadillac CTS without navagation and can not figure out how to set the clock. Owner's manual doesn't offer solution.
This worked on my 04 CTS. This is a CTS without the GPS.
1) Turn key to On or Accy
2) Wait for the radio/clock display to load up.
3) Push the Tune/Select button at the lower right of the radio display. Nothing will appear to change.
4) There is a button to the right of the radio diplay with two horizontal lines on it. Push the lower of the two horizontal lines. The clock set option should appear.
5) Turn the Tune/Select button until the time is correct.
6) Push the Tune/Select button to lock the time in.
Hope this helps.
Don
Mar 28, 2011 | 2004 Cadillac CTS
2 horizontal lines which scroll
Place a 2 to 3 prong AC adapter on the power cord. It will isolate the ground and should fix your problem.
I hope this was helpful, best wishes.
Apr 15, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Same crazy problem here! I have a converter box and can't figure out how to get the dvd to work. I managed to get a b/w picture to come barely come in (has rolling horizontal lines). What channel is it...
The converter box simply installs between your Antenna and your TV (tune to channel 3 or 4) http://digitaltips.org/docs/FlosTips.pdf
A dvd that does not Record is designed to simple install into a separate Input connection on the TV (do you have a VCR/DVD combo?)
Do you have an older TV with only one "Input" for a cable connection? (no Red/Yellow/White Inputs) if yes you may need to take a trip to Radio Shack
Mar 12, 2010 | Zenith Z25X22S 25" TV
Picture is only black screen with white lines
Are the console and the TV both tuned to Channel 3 or Both to Channel 4. On the SNES there is a little switch on the bottom of the back labelled 3 on one side and 4 on the other.
May 31, 2009 | Nintendo Super NES Console
Does the Sharp 32U-F810 TV have a digital tuner?
No it only supports analog. I'm pretty sure no CRT TV would be digital reception. Here is a link... Scroll down until you see the specs. First line is your answer: http://www.ciao.com/Sharp_32F540_CRT_TV_CRT__10021988#productdetail
Apr 27, 2009 | Sharp 32U-F810 32" TV
My 96 year old Mother-in-law has a Sears (SR) Model 580 television. We cannot figure out how to get it to Channel 3 so as to hook up a new Federally Sponsored reception box. There is a panel for...
Those adjustments were marked with letters so you could set ant position to any channel, and the channel know was marked A-L as well. The set came with labels you could put into the knob with the numbers.
Associated with each of those adjustment screws should be a small switch, labeled (if I remember correctly...I was a Sears TV tech over 10 years ago and haven't seen one of these sets since then!) VL, VH and UHF. VL is for channels 2-6, VH 7-13 and UHF 14 up. There might also be a little indicator window showing how far up the band you've gone. There may also be a switch marked AFT on/off. If you have that, turn it off to set the tuning and turn it back on when you're done. Put the switch on VL and turn the adjustment until you're tuned to channel 3. You'll know when since you'll see the programming.
I hope I haven't been totally off base. Like I said it's been a while. If this has helped, please feel free to give this solution a good rating. (If not, please feel free to pretend this never happened!)
Apr 21, 2009 | Televison & Video
Rolling horizontal lines on the display of my plasma tv
if u r connected to an ant. it is due to poor signals from the ant so get a booster or amplifier for the ant.
Mar 04, 2009 | Samsung HP-T5064 50 in. Plasma HDTV
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
Proscan 32LA30Q Television Logo
85 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
