Question about Cuisinart DCC-1200 Coffee Maker
After brewing coffee does not stay hot.
Is ther a repair shop l can take it to?
  • 8,596 Answers
Unplug the coffeemaker for one full hour.
When you replug it, go to Auto-Off - change the time from "2:00" to "4:00", and then brew another pot. Immediately after the brewing is done, set the coffeemaker back to Auto-Off and see if your problem is resolved.
If not, it may have deeper problems. These coffeemakers have a 3-year warranty - call Cuisinart to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Feb 21, 2009
My cuisinart grind and brew timer goes off after it brews than the coffee doesn't stay hot should I replace it?
A small appliance repair shop should be able to replace the thermostatic microswitch that keeps the heat on. Coffee pots are really not too expensive if you cant get it fixed.
Jan 28, 2015 | Cuisinart Coffee Makers & Espresso...
Water is hot but it does not brew the coffee.
Hi. How do you know that the water is hot if it wont brew coffee. They have different boilers to do each function. Hot water function. steam function and brew funtion. Sounds to me that you have a clogged brew unit. If hot water is coming from the water outlet, the you do have a fault with the brewing side of things. Dazza REPAIRER
Sep 23, 2011 | Keurig Elite B40 Coffee Maker
I have a Bunn coffee maker with date code of 401406. It is almost 4 years old and still brews perfectly. The warming plate does not heat up any longer so the coffee will not stay warm after it is brewed....
The manual for this coffee maker can be found at this link:
http://manualheaven.com/assets/bunn-nhbx-b-contemporary-coffee-maker-manual.pdf
While the manual does not contain repair instructions, it does have some troubleshooting tips to follow if your coffee is not staying hot.
May 04, 2011 | Bunn NHB Coffee Maker
I have the grind and brew thermal coffeemaker. The water does not get hot enough for steam to come off of the coffee when it is poured.
Hi, I have owned that coffee maker for years.
After it brews coffee, it does not have a warmer to keep it hot. It has a thermally insulated carafe. Such as regular lunchbox thermos jugs have. The reasoning behind this is that coffee heated after it is brewed spoils in a short time. (Of course, unheated coffee gets cold).
What that translates to for you with regard to no steam is this. As soon as the coffee maker finishes brewing your coffee, open the top of the carafe, stick in a spoon and stir it.Then pour it. (I learned the stirring part working in a restaurant).
If you have to wait before you drink it, do the same. Stir it first.
Hope this has been helpful
Love that grinder!
Best Regards,
Mark
Jan 04, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Tried to brew 8 cups as I normally do. Half way through brewing it quit. Half the water still in supply tank. Red light stayed on. Hot plate went cold. Carafe contains about 3 cups of coffee.
There is a thermal cutout fuse located under the hot plate..these are designed to cut to power off if the plate gets too hot...the cutout will have some numbers on it and it looks like a metal cylinder with a lead coming out of either side of it...the numbers on the cutout are the temperature in degrees "c". you will need to make sure to replace it with one of the same type...Radio shack used to carry these, but I don't know if they still do...they are not very expensive though so fixing the unit would be an option...if radio shack doesn't have them anymore you could try the i-net or a local appliance parts store/repair shop..
Dec 21, 2010 | Braun FlavorSelect KF 187 Coffee Maker
We have a CBC-1600 10 cup coffeemaker. after brewing the coffeemaker beeps and turns off. The hot plate part of the coffeemaker will not stay on for longer than 5 minutes.
The CBC-1600 is designed differently than you might expect. The stainless steel, insulated carafe is designed to keep the coffee hot instead of a hot plate keeping a glass carafe hot. Some people like that style better (including me). Some people - like my dad - don't think it keeps the coffee hot enough.
Your coffee maker is working exactly as designed. The carafe itself is designed to keep the coffee at the same temperature as it was brewed.
Dec 24, 2009 | Cuisinart Coffee Makers & Espresso...
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee pot warmer is not working
I called Cuisinarts repair center and they had me set my auto off button. It had been set to 0 so it shut off as soon as it started brewing. If you turn the switch to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. Then when you stop hitting it it will remain at that time after you brew your coffee. If that doesn't work you can call the help line at 800-726-0190, just give them your model number and serial number, the device carries a 3 year warentee
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
317 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
