Question about E-Machines eMachines Desktop PC
My T6410 keeps freezing, shutting down on its own then blinking, turning on by itself and then giving me a checksum bios message something to do with a floppy drive a but I dont have one of them. it seems that the only time it will work right again is if I keep it off for an hr or so, then I boot it back up and it starts working for a a few minutes till it happens again. I know its not the hard drive, memory or any of the pci cards, Ivetested them already on another pc, so it's either the motherboard or processor. Cananyone figure out which one of the two it might be so I can replace it? Thanks
  • 37 Answers
You may need better cooling for the cpu.
Posted on Mar 31, 2008
Change the Power Supply.
Posted on Jan 13, 2008
  • 34 Answers
Have you tried a BIOS firmware upgrade?
Posted on Jul 30, 2007
SOURCE:
Can you please help me how to fix the BIOS ROM CHECKSUM ERROR. TO MY MOTHERBOARD (TRINITY 400 S1854 AGPX4-PCI-ISA) i reformat the windows NT version 4, and after i restart, the message come bios rom...
turn the computer off
now turn on and hold down the delete key until the bios screen appears
in the boot tab select first boot as the cd disk, install the cd for win nt in that drive
close down the cd and then restart and it will boot from the cd
BY reformatting the hard drive win nt you have wiped the win nt operating system from the hard drive
Feb 17, 2018 | Tyan Trinity 400 S1854 Motherboard
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Mar 05, 2010 | Microsoft Windows XP Professional With...
Will not boot up. Get Bios Rom Checksum error, Keyboard error or no keyboard present. Manually shut down and turned on literally 30 times this morning before it would boot up. Then after a couple of hours...
most times a checksum error refers to the cmos battery. you may want to replace the battery and see if that helps. However this can also be a symptom caused by a bad power supply or a faulty board. Make sure you check your motherboard's capacitors for swelling or leaking.
hope this helps.
Dec 10, 2009 | HP Pavilion m7480n (882780389410) PC...
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
Laptop keeps shutting down, and restarting itself
Have you sorted this yet?
Any problems just come back to me :)
Feb 19, 2009 | Compaq Computers & Internet
My Toshiba Satellite M45-169 keeps freezing
1. The battery on the motherboard has died. Replace battery.
2. The BIOS is corrupt, reflash BIOS.
Most likely #1, very rarely #2. Pop out the battery on the motherboard and replace it, after the first time you boot up your computer, go into BIOS and set everything the way it should be for your computer (usually just time and date) and then after each sequential time you reboot, that should take care of your problem.
Jun 24, 2008 | Toshiba Satellite M45-S169 Notebook
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
cheak bios settings diable serial port parrel and any onbord stuff u wont use ok
Feb 01, 2008 | ASUS P5LD2 Motherboard
E-Machines eMachines Desktop PC Logo
158 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
