KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
My KitchenAid Whisper Quiet top loading clothes washer fills but doesn't wash or drain. It hums and blew the breaker. I already checked the motor/transmission coupling but it is in tact. If the lid is open, the humming stops, when lid closed humming starts again telling me the lid switch is ok. Model No YKAWE752WW1 Help!
  • 4 more comments
  • jchimenti Jan 31, 2009
    I have already dropped the motor to check the coupling and both the motor side and transmission side spin by hand. Could it be the capacitor?
    There is water in the machine. Do I have to remove the water before removing the pump?
    Took off the pump. Both the motor and pump spin freely by hand. Now what? Capacitor, Motor Switch or Timer Control? How do I know which one?
    Testing the capacitor. I think I discharged the capacitor to start. Then, I set my multimeter to Ohm, touched the multimeter leads together and the meter went to the right (0). Then, I touched two multimeter leads, one each to the leads of the capacitor and nothing happened. Does this mean a bad capacitor?
  • Ron Coons
    Ron Coons May 11, 2010
    possible something is causgt, either in the pump assy, or betwen the tubes even. if you remove the cabinet the pump simply "clips" off the motor assy, andthen you can try to spin the machine, with outh the pump attached the motor will spin( if theres someting in the pump), if that holds the same result, you can also drop the motor assy( it too is only "clipped" on, andthen see ifthe motor start while resting on floor in which case would lend me to believe taht the problem is with the tranmission ( or something between the tubs)
  • Anonymous Mar 15, 2014
    maytag lat9700 checked breaker, no hum
    President:
  • Washing Mach... Master
  • 2,651 Answers
No, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Posted on Jan 31, 2009
Spin cycle doesn't spin
what kind of washer is it top load or front load and brand.?
May 26, 2012 | KitchenAid KAWS850L Top Load Washer
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Washer doesn't fill with water and begin wash cycle. I can hear it instantly draining out rather than fill, and has ran my well dry. We replaced the water pump a month ago, and it washed a few loads of...
Sounds like siphoning. This can happen if your drain pipe is too low and you run the drain hose right into it, or if there isn't any kind of air gap between the drain hose and pipe. Usually it shows up when trying to fill for the rinse cycle - it drains as fast as it fills. Or it might not fill at all. Order a "siphon break kit". They're cheap and easy to install
May 26, 2010 | Roper RAS6233KQ Top Load Washer
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
My machine will nto agitate or drain, but fills fine.
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Jan 07, 2009 | GE WWSE5200B Top Load Washer
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
275 people viewed this question
Top Washing Machines Experts
