Not sure if this is correct but pilot seems to light stays on for 30 seconds and then shuts off but not before "bursting" a few times (like a small gas burst) then it relights and starts the process over again.I hear lots of clicking and I assume that's the pilot trying to light? should I be worried?
  • 146 Answers
Is this your home furnace. sounds like you need to clean your hot surface ignitor
Posted on Jan 31, 2009
  • mopar440man Jan 31, 2009
    sorry i mean clean your flame sensor
My water heater pilot light won't stay lit
I would try cleaning the thermo couple surfaces with some steel wool... Both where the flame contacts the sensor, and the electrical contacts. Even a small increase in voltage may be enough to hold the pilot valve open. Both black, and white soot on the sensor end, can act as an temperature insulator, lowering the output voltage.
As for finding the part numbers for replacement: http://www.reliancewaterheaters.com/media/48391/242117_RPPCR01111-Reliance-Parts-Catalog.pdf
Feb 17, 2016 | Water Water Heaters
I have an American Range fryer with a thermopile, the pilot will stay lite until the burner comes on then it seems to blow the pilot light out, not every time either....any ideas?
The pilot light has only a small orifice and this can carbon shut with time; with a small wire, you can try cleaning it.
They may also provide a separate adjustable valve for the pilot and this setting may have drifted over time, shrinking the flame height and therefore resistance to being extinguished.
Sep 19, 2014 | American Range Kitchen Appliances - Others
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
The water heater pilot does not stay on?
The pilot light on hot water heaters is controlled by a thermocouple, a small copper rod that usually sits in or very close to the pilot light flame. When they go bad, which is not unusual, they do not allow the gas line to stay open and feed the pilot light. The easiest thing for you to do would be to replace the thermocouple. When following the pilot light lighting instructions, be sure to hold the valve button down for 30-45 seconds in order for the pilot light to heat the thermocouple prior to turning on the gas burner.
Sep 11, 2010 | Reliance Water Heaters
Pilot light will not lite; plenty of propane. What position does the knob need to be in to lite the pilot. I see pilot, on, and off positions. It is a Williams gas unit direct vent, does not blow hot air...
The knob needs to be turned so the arrow is pointing at "Pilot". It is the only position you will be able to depress the knob all the way down. Once you light the pilot, keep holding down the knob for 30-60 seconds. When you release the knob, the pilot should stay lit if it's working properly. If not, here's a few things to check. Is the pilot flame blue? Is the flame actually heating the thermocouple end? The thermocouple has to get hot enough to allow the gas to stay on to the pilot. Also look at the tip of the thermocouple. It should be smooth and rounded. If you're pilot flame is a lazy yellow, after time it will burn off the tip of the thermocouple, causing pilot outages. Replacing the thermocouple is usually the easiest fix it and is probably what you will need to do. But if your pilot flame is that lazy yellow, you will also need to clean it by either a tiny broach needle or using canned air (with straw attached). Be careful and because propane is heavier than air, smell low to the floor before lighting it to make sure there is not a gas leak. To be safe, close the gas shut off valve and air out the room before lighting and always follow the manufacturer's lighting instructions printed on the heater. If doing this seems too difficult or scary, then call your local propane co and they will send out a serviceman to fix it for parts and labor. Good luck! Douglas
May 25, 2010 | Heating & Cooling
Need to light pilot cozy brand gas wall heater
Is there a "Pilot" marking on the knob? Try moving the knob 1/2 way between on and off and depress the knob. If you are in the correct location, the knob should depress in about 3/8 of an inch. Once you find the location where you can depress the knob, there should be a red sparker button that you can snap to light the pilot. Depress the pilot knob and snap the button a few times. There may be a small viewing port at the pilot. It may be covered by a small metal shield held on by a thumb screw. You can remove the shield to view the flame. OK so now you can depress the pilot knob, snap the sparker, look for the flame while still holding down the pilot knob and count to 30. Slowly release the pilot knob and check to see if the pilot is still on. Once it stays lit, rotate the knob to the "ON" position.
Jan 04, 2010 | Cozy Heating & Cooling
Not sure how to relight the pilot light. Some point during the night it just went off. Not sure how or why that happened either. I have tried to do a few things but need help
To light your pilot you will need to find the gas valve assembly. It will be a block of aluminum with a plastic knob and a few pipes attached to it. Once you find it, rotate the knob to the pilot marking on the knob. You will know when you are at the proper setting because you will be able to depress the knob into the gas valve about 3/8". Once you do that, there will be a small red button which you can snap causing a spark at the pilot. There may ba a small viewing port covered by a removable metal shield. OK, Depress and hold in the knob, snap the red button a few times. Keep holding the knob in, look into the viewing port for a blue flame. If no flame, snap the button a few more times looking for a spark. Once you see the flame stop snapping but continue to hold the knob in. Count to 30. Slowly let the knob out watching that the flame stays on. If it starts to go out, quickly depress the knob and hold for a minute. If it continues to go out, you have a bad thermocouple and it is not letting the pilot stay lit. If it stays lit, rotate the knob to On. A few seconds later and if the unit is calling for heat, it should light the main burner. If you need a new thermocouple, go to a good hardware store or Farm Center (bring the old part with you) and ask for a new one.
Dec 29, 2009 | Williams 1403622 Gas Compact Heater
Why won't my roper gas range (FGS337KQ) stay lit? The oven will light for 30 seconds and then shut off. Ignition is working.
you may have air in you gas lines make sure to hold pilot setting down for about 30 sec then light
Oct 30, 2009 | Roper FGS337 Gas Kitchen Range
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
