Question about Frigidaire GLER642A Electric Dryer
Changing heating element
What is the easiest way to change out the heating element
  • Frigidaire Master
  • 8,220 Answers
No need to buy the whole pan. The replacement coil is way less. 5300622032
Very easy dryer to repair. Start by popping the top and then removing the front. Get te drum out and remove the heater assembly. Remove the old coil. NOTE: when replacing the new coil be vewy vewy careful not to stretch the coil too much as this causes a hot spot and shortens the life of the coil considerably as in like one load maybe. LOL.
changing heating element - db4f97d.jpg.
Posted on Jan 31, 2009
    President:
  • Frigidaire Master
  • 2,651 Answers
Theres only one way, youll need to remove teh drum,(its located behind it) the new heater assy comes attached to the pan so youllneed to undo the old heater pan and change out, not a bad job..( i would check to see if the heater is indeed bad (physically broken) and you dont have a thermostat issue giving you a no heat problem)
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
White knight tumble dryer not drying clothes. element is still hot. what is the problem?
Mar 23, 2010 | Whirlpool Dryers
The oven wont turn on,fan works but heat wont come on
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer. Can give further advice if you provide a model number. Good luck!!
Mar 10, 2010 | Fisher and Paykel Ovens
Tip
on May 10, 2010 | SNK Knight 43AW Electric Dryer
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Just replaced the heating element
Apr 11, 2009 | Dryers
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
Nov 01, 2008 | Dryers
Frigidaire GLER642A Electric Dryer Logo
135 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
