Question about Denon DVD-1000
Denon DVD 1000 & DTS playback
Whenever I play a DTS DVD, I am unable to pick up anything other than Dolby Digital through my Yamaha DSP-AX620.
This is with DVD audio output Dig/normal
and
DSP AX620 set to 'auto'.
Any clues?
Wheres the question
Posted on Jan 31, 2009
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Right now my reciever will only play with two speakers (L and R). How do I get the 5.1 DTS back?
Are you using single digital coaxial or optical digital or the stereo RCA cable.
You might have that buttons on the remote for surround,2channel,3channel or 5.1 channel. orGo to the DVD's setup menu and click on "Audio Setup" or on "Languages" if there is no Audio Setup option and choose "Dolby Digital 5.1." (If you have a5.1, 6.1 or 7.1 system select "Dolby Digital EX" if it is an available option.) Depending on the age of the disc, the "Audio Setup" on the DVD menu may give you several choices: "5.1 Channel Surround Sound" or "Stereo Playback." If it's an old DVD, it might even say Dolby AC-3 (the professional designation for Dolby Digital 5.1). New DVDs may offer "Dolby Digital 5.1" and "Dolby Digital 2.0," the latter being stereo. Some of the disc menus offer only "Surround Sound" or "Stereo" options.
Aug 14, 2009 | Yamaha RX-V463 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Samsung DVD-R155 will not play in Dolby Digital surround sound
You need to buy a digital coax cable Just 1 run out of player and into amp!
Dec 06, 2008 | Samsung DVD-R155
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Yamaha rx-v595a problem with dts signal
the unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Dec 28, 2007 | Yamaha RX-V595A Receiver
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Televison & Video Logo
97 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
