Question about Hotpoint WMA76 Front Load Washer
Hotpoint WMA76s Hey FunkyBoogy, Wondering if you could help please. We have the above Washing Machine, everything seems ok, except it has started to overfill then comes up with an error that in the manual says means that it can't get water. If you advance the program, it finishes ok, but it really gets to full to leave it on it's own... what do you think? Thanks, Jon.
  • 641 Answers
It sound that your problem is cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help,you should replace the level switch unit. Good luck !
Posted on Jul 30, 2007
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
My WMA76s is extremely noisey on a spin cycle only. The problem is getting far too loud. It is only when there is a load inside (no clothes-no noise) Is drum bearing at fault? I only ask as its quiet as a...
if this is a front load washer you broke the spider gear from using to much detergent.it eats at the gear and unfortunitly it's cheaper to replace it than to fix it.if it's a top load washer it sounds like the tranny is bad,model number is no good,can't look up your machine
Jan 23, 2011 | Hotpoint Washing Machines
Hotpoint bwd 129 leaking from underneath (left side when looking at the machine) - i have checked the plugs at the back - all okay.
Hotpoint bwd 129 leaking from underneath This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 08, 2010 | Washing Machines
Hotpoint wt965 f04 error
F04 indicates that the pressure switch is jammed on empty,
check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an enginner
This really is your only option.
Plz rate my solution
Thanks.
Dec 18, 2008 | Hotpoint Ultima WD72 Front Load...
Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
May 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine tripping everything in the house
Washing machines take out ring main fuses if there are faults in the machine:
washers heater unit
motor
or suppressor.
Also water may have breached a seal somewhere and cause a short inside the electrical compartments.
To fix a fusing washing machine you have to use a diagnostic electrical meter that puts high voltage across the appliance - Not something I can offer more info on. So whatever has happened (and in the interest of safety) you would probably want a qualified proffessional to take a look or as a last resort a hotpoint engineer!
Feb 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA76 Front Load Washer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
