Question about HP D8597A Keyboard
When I press certain keys such as "a" I get "ai" . Also, several other keystrokes result in 2 different letters rather than the one I pressed.
  • rbwilliams06 Jan 31, 2009
    This problem occurs with any keyboard input at all times. I spent 40 minutes with an HP rep and he could not solve it either. We tried sticky keys settings, drivers, international fonts .....still no fix. Is there a keyboard reset function somewhere for multimedia keyboards. I am sure that I just accidently caused this problem when I dusted my keyboard while on and accidently pushed many keys simultaneously. When I switch to an old keyboard the system works fine.
  • Misterixas May 11, 2010
    Did this happen to all programs you are typing in? Even at log-on?
    Problem Solver:
  • 7 Answers
Disconnect your keyboard then reconnect it.
Posted on Feb 15, 2010
  • Smart839 Feb 15, 2010
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
Keyboard incorrectly types a mixture of letters and numbers when certain keys are used.
There are a couple of things you could try:
1. Remove the keyboard following a service manual for your laptop, and reseat the ribbon cable underneath it.
2. If the problem still isn't solved, the keyboard should be replaced
Feb 03, 2013 | Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
When press some tasts, istead of 1. 0, I have / 2. U , I have 4 3. I, I have 5 4. O, I have 6 5. P, I have * 6. J, I have 1 7. K, I have 2 8. L, I have 3 9. M, I have 0 10. /, I have + 11. [,...
Hello-
Welcome to FixYa, the world's largest product support community.
I just want to verify the problem here... If you press a certain key the computer identifies or sees it as a different keystroke? Say you press the letter A, instead of getting the letter A up on the screen it gives you something else?
If that is the case it sounds like an issue with the keyboard itself. You see a Keybaord doesn't have a driver unlike other components like the sound card or the video card, unfortunately. If you wish to check and see if it is a define Keyboard hardware problem, on many Sony models, holding alt + F10 at boot will start the factory restore process. You can restore the computer to it's factory settings to isolate the issue, if restoring the computer to factory settings doesn't fix the issue, then the whole keyboard assemble needs to be replaced.
I hope this sheds some light on the issue your having w/ your laptop.
Regards,
Deathschythe
Jun 04, 2011 | Sony VAIO VGP-WKB1 Keyboard
I have an hp mini laptop..whenever i press letters u,i,p,o,j,k,l,m it shows numbers 4,5,6,1,2,0. maybe i had typed something which made this like this..how do i do it.
The problem is that you have to turn off the number lock hold FN key and press the scroll button wherever its on your keyboard usually its after the f12 key,, that should fix your problem...
Jun 08, 2010 | HP 2133-1 Mini-Note PC
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
Doubled accent with single keystroke (using Language Bar)
It's just a glitch that may happen from time to time. The first thing is to reboot, and more likely than not it will be gone.
Dec 16, 2009 | Microsoft K5100141 Keyboard
On certain of the letter keys on the keyboard when you press them it types a number. on those letter keys there is a number in the upper right corner. how can you type the leteter. thank you
Is the number in the upper right corner a different color? There might be a key you can press that changes those letters from the letter on the key to the number on the key.
Jun 28, 2009 | Computers & Internet
Keyboard malfunction?
HI,
Run a quick diagnostics on the keyboard . To check if the keyboard is OK .
To do the same
1. Shut down your computer
2. Hold down the Fn key and press the power button
3. PSA diagnostics screen would appear , which would test the LCD and you would hear beeps
4. Second a memory test would run
5. It would prompt you to run advanced memory diags , say no to the same
6. Enter the dell 32 bit diagnostics on the next prompt
7. Run a custom test on the keyboard.
Do post the results .
Thanks
Proton
Jan 25, 2009 | Dell Inspiron 1501 Notebook
IBM T40 Keyboard Question
Numlock is the keystroke to fix your problem.
Oct 13, 2007 | IBM ThinkPad T40 2373 Notebook
HP D8597A Keyboard Logo
161 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
