Question about NetGear RangeMax NEXT WNR834B Wireless Router
Wnr834b passphrase won't work
New computer- windows vista can't get wireless to sign on
  • cooler34788 Feb 23, 2009
    I do not want to have to use a password so I set up an unsecured network and at some point it began to ask for a password and now I am stuck. I have tried the reset button, security settings, and the software that is supposed to solve the problem. I switched out the computers to focus the problem. Nothing changed so it must be the router. Months ago I used a password. I am ready to break the seals and go inside to see if there are any jumpers or switches that will reset the router. Anyway, got any ideas? Ice
  • 854 Answers
Hello jsnow4 & cooler34788,
For vista OS;
Here are some troubleshooting steps that I suggest you try:
1. Go to "Control Panel" ( switch it to classic view )
2. Click " Network & Sharing Center"
3. At the left side of " Network & Sharing Center", click Manage Wireless Connection ( under task)
4. Delete the profiles of your Wireless connections particulary the one you named for your Netgear wireless ( this is also known as SSID).
5. Click close including "network & Sharing Center"
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
Since this is an unsecured wireless, Vista will warn you if you wanna connect anyways. Go ahead and connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 12, 2009
I have a Kingston KNE100TX network adapter and I can't find a Vista driver which works
Windows vista is the most modern innovation in computer systems. Vista has the wireless also known as wifi an improvement over the network adapter devices. Windows vista computer can teleconferece with network adapters only requires that the adapter be a modern innovation to meet the new features in vista computers. The KNE 100TX is an outdate version communication device comparted to the computer with Vista. The adapter would continue to fucntion only when an older version computer either windows millennum, 2000, 98 were used to derive networkc connectivity.
Feb 08, 2011 | Kingston KNE100TX /REFKINGSTON 10/100 NIC...
I have the drivers on CD but I have a new computer with windows 7 and the drivers are only for 2000 vista or xp. is there dirvers for windows 7?
If you cannot find the Windows 7 drivers, try using the Vista drivers as they are pretty close: I am mostly using Vista drivers under Windows 7 Ultimate.
Hope it helps.
Dec 30, 2009 | Blitzz Technology BWI715 Super G 802.11g/b...
I want wireless driver for a105-s4244
Hi
Thanks for using FixYa. You can download the drivers forToshiba A105-S4244 from the link---
ToshibaA105-S4244 Drivers
Please do rate the solution and revert for furtherassistance.
Thanks
Rylee
Nov 18, 2009 | Toshiba Satellite A105-S4244 Notebook
Cant conect to internet using wirles with Windows Vista
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck.
Aug 30, 2009 | Microsoft Windows Vista Home Premium with...
I have a D-Link AirPlus DI-524 Wireless Router. I have no problem connecting the computers in my home that have windows XP installed. We have replaced two of the computers in the house with laptops that...
I have had exactly this problem and after MUCH work downloading new drivers for the Vista Pcs and updating the operating system in the DI-524 found that the 524 does not operate well with Vista. A new DI-624 integrated well with Vista, and installed with no problems. Good luck!
Feb 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Getting Vista to use my wireless internet connection correctly
One question, is... do you need to enter a KEY or is this an open network?
I have found that with a new computer, you need to do the following to connect.
If this is an open network, then leave your router running, and just do a cold boot with your computer.
IE: Shut down, count to 10, and then re-start.
You may also need to connect (by network cable) to your router and make sure the wireless is turned on.
Most new rountes start with the wireless disabled.
Jan 01, 2009 | Microsoft Windows Vista Home Premium with...
Traveling with Vista
re install your wireless drivers and try it ........
Dec 22, 2008 | Microsoft Windows Vista Ultimate Edition
Wireless Network with Windows Vista
Following is the link where you can see a comprehensive list of all compatible wireless cards for Windows Vista:
http://winqual.microsoft.com/HCL/ProductList.aspx?m=v&cid=711&g=d
Jul 29, 2008 | Microsoft Windows Vista Home Premium with...
Vista
Confused?
Got this from Microsoft new Operating System (OS) next from the succes of winXp.
Try this link to know more VISTA
Feb 15, 2008 | Allied Telesyn AT-WCU200G Wireless Adapter
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
130 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
