Question about ASUS P4P800S-X (610839118175) Motherboard
Please help me...
I can't switch dvd-rw with sata cable on this - asus p4p800s-x.
  • 1 more comment
  • requiemrequi Jan 31, 2009
    i have 1 cd-rw on ide and this dvd-rw, wich i can not conect with sata cable.
    when i  conect and turn on computer, screen is stoped and i can't enter in bios.
    i have 2 empty sata and 1 emty ide.
    i have this motherboard p4p800s-x.
  • Misterixas May 11, 2010
    Have you checked that the power your DVD-RW drive gots is either from ordinary molex ( )either A 15-pin Serial ATA power receptacle ( ) but not the both at the same time
    Please explain: you can not connect DVD-RW drive, that has SATA or ATA (PATA) plug? How many connections SATA and ATA (PATA) are empty in your motherboard
تعريفات asus p4p800s-x
Posted on May 17, 2010
Sata adapter
Please check the Sata cable and the power cable
Jan 24, 2014 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Sata hard drive not support
The hardware of your system need more hardware capacity and some slots on the mobo for the sata cable.
Apr 29, 2012 | ASUS P4P800S-X (610839118175) Motherboard
ASUS P4P800S-X SATA problem
It could be a bios thing have a look a there for a option to chage from IDE to SATA
Mar 31, 2012 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
NO POST ON BOOT UP AND NO VIDEO ON MY DESKTOP COMPUTER. I have an ASUS P4P800S MOTHERBOARD. The RAM is fine, power supply is fine, video monitor if fine. what could it be?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
May 13, 2011 | ASUS Motherboard P4P800S...
Cannot read DVD+R
It could be a problem with the lens, you should try cleaning the lens, and clean all the cable ribon,and also fit it tightly.
If you take a little risk but you can solve it self.
follow the instruction: Don't panic its very simply.
1. When running your pc , open the drawer.>
2. switch off the ac power
3. remove power cable & sata or pata cable
4. remove all the screw from the back side
5. press clip to open the font panel
6. reverse the cd/dvd rw
7. just remove the cover
8. clean the optical lance
9. remove all the ribon and clean by eraser or sharp blade.
10. use a little ( not much )oil place on two steel shaft
11. cover all the equipment
12. now you can fit to your pc
If it does the same problem please change the cd/dvd rw because the lance has defected.
Hope it will help you.
Feb 22, 2011 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
My ASUS P4P800S-X Motherboard won't boot up, it goes to the windows loading page, then a blue page as if the computer is to start, then restarts and will continue to do this until I switch the computer...
One bad lead will cause your computer to continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Oct 05, 2010 | ASUS P4P800S-X Motherboard
Asus p4p800s-x won't boot and no display on the monitor..
get a better power supply, as i understand it, youre computer is getting too little power from it. pick a power supply with more volt
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
SATA ports don't work
Thank you for using fixya. And I'm glad i could help.
Feb 01, 2009 | ASUS A8R-MVP Motherboard
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
ASUS P4P800S-X (610839118175) Motherboard Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
