Question about Canon CanoScan 4200F Flatbed Scanner
Light stays on all the time
I have had problems with the scanner light staying on sometimes. I downloaded/installed the latest driver and not the light stays on all the time. Is this a problem with because of Vista or is it the scanner software? I have to unplug the scanner power when I am not using it.
  • Ron Shepherd
    Ron Shepherd Feb 23, 2009
    Thanks, this might be a fix except I haven't a clue how to open the twain driver. I have searched through the help screens in Vista and looked at the device manger but no where can I find any place to open it.
  • Ron Shepherd
    Well I'll be darned. I spoke too soon. I found the driver through Photoshop. All the years I've used a scanner and I didn't understand this simple thing. Thanks spammster, you taught me a lot with your answer. -Ron
  • 3 Answers
Open the twain driver,
go to preferences and set the timer for the light shutoff.
it is probably set to something high.
remember though: when the light goes off, the lamp needs to heat up again
Posted on Feb 22, 2009
Air bag light stays on also alternator and abs 3 lights at the same time, I want how to reset them
what is causing my airbag light, abs light and battery light to ...
https://answers.yahoo.com/question/index?qid...
Jul 12, 2014 - My battery light stays on sometimes it might blink on and off. But the problem is i can be driving my car and my airbag light and abs light will ...
Electrics HELP! Engine management light, Brake, Airbag, ABS, EPS ...
www.civinfo.com > ... > Bugs, faults and irritations
Feb 12, 2012 - 18 posts - ‎5 authors Airbag light. ABS ALSO - the speedometer, rev counter and engine temp ... 30 mins driving (apart from engine management light which stays on). ... I have ruled out problems with the alternator and the relays - they're all fine.
airbag abs srs light diagnose without a scanner air bag ...
? 4:14
www.youtube.com/watch?v=tIBjIr9a42w
Feb 6, 2010 - Uploaded by vehix411 airbag abs srs light diagnose without a scanner air bag ... Alsowhen I tried the scan plugging the paper ...
Oct 30, 2015 | 2010 Ford Escape XLS
SRS light stays on vrx lancer 02 how do I turn it off please!
use a scanner to confirm the cause of light stayed on. Sometimes the reason is under the seat of driver or front passenger as they are moved either forward or backward and one slight reason is the connector under the seat is not well connected -moved- and have not a good contact and light comes on.
Sep 06, 2012 | Cars & Trucks
Scanner error e225 in canon mf4320d
This is a common problem and can be corrected by updatingthe firmware to the latest release. The firmware, which must be installed to the printer itself.When you install the firmware from your computer, it gets installed on theprinter and stays internal to the printer. You can download the firmware at the following location: "http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/black_white_laser_multifunction/imageclass_mf4350d#DriversAndSoftware Hope this will help you. Good Luck.
Oct 20, 2011 | Office Equipment & Supplies
The "wireless on" light will not go from red to blue
Try this :
1.Download the latest wireless driver for computer (7.20 REV:A, 2/20/09) - Might change depending on your CPU, (7.20 REV:A is for AMDs)
2.You will also need to download the latest Bios (F.42, 3/9/09)
3.Latest version of HP Wireless Assistant (3.00 REV:K, June 2009)
NOW YOUR READY TO START FIXING?????
INSTALL STEPS: You must use this order for an 100% fix
1.First flash your computer with the latest BIOS and if should restart after its complete.
2.Install the wireless driver
3.Install HP Wireless Assistant
4.Restart your computer
5.Flash Bios again
6FIX
Apr 20, 2010 | HP Compaq Presario V2000 Notebook
Blackberry 8100 shutting off & turning on
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
then, download and install the latest Handheld Software for your model then open DM and run the application loader once the USB cable is connected to the device. Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=1905AEDAB9BF2477EDC068A355BBA31A&dl=89511F30EDAF2A957D19D07C35FF8B6F
Just fill out the form and the download is free for you.
Oct 01, 2009 | RIM BlackBerry Pearl 8100
The copy light won't stay to copy
That is often an un-fixable problem. However, sometimes a fully charged fresh set of batteries will handle. (Use high-quality rechargables, not disposable alkalines.) Also try power cycling the unit several times.
Sep 27, 2009 | HP CapShare 920 Handheld Scanner
The 2400 Scanner quit scanning 35 mm slides as the top lid light
problem in the driver so pls check latested driver in the internet and download it then you problem will solved
Mar 17, 2009 | Epson Perfection 2400 Photo Flatbed...
Wireless wont stay on
- Kindly install the latest driver for the wireless card.
Mar 13, 2009 | Acer Aspire One PC Notebook
Wireing problem???
you have a loose ground wire somewhere.
Have you installed something lately?
Jan 24, 2009 | 2001 Chevrolet Cavalier
Monitor issues.
plz boot in safe mood and uninstall the display driver and reboot normally.if your problem persist then download the latest display driver from the net and install it.
Apr 01, 2008 | Dell Latitude C610 Notebook
Canon CanoScan 4200F Flatbed Scanner Logo
216 people viewed this question
old marine
old marine
