Question about SGI Silicon Graphics GDM 4011P 20" CRT Monitor
Turns ON only after a day or so of rest.
My SGI GDM-4011P monitor doesn't want to turn ON. But sometimes, it does! I've already turned off Power Save Delay options,double checked connections, etc., but just don't know how to 'predict' if it would turn ON when I push the Power Button. If I wait something like 1 or 2 or more days of not using it, it would sometimes be turned ON. It's really puzzling, could you help me please?
  • Gerry Asuncion Apr 15, 2009
    Short of opening up the monitor, I just used a workaround:
    I leave the monitor on from then on. At least, I didn't have to worry about it not turning on.  :-) (My only problem with this is the phantom power consumption.) :-(
    But if I really need to turn it off, u just pull off the plug from the power outlet rather than use the power switch, which, if I plug it back again, strangely turns on without a hitch! So perhaps the problem may be related to the switch.
    I suppose my problem may be a "dry joint" on the switch (if the meaning is right..?), but I don't have confidence to open up & have a squiz yet. Thx anyway, Silverdragon!
  • 12,061 Answers
I think you have a faulty Power Supply, more than likely it is gonna be my old favorite faulty Electrolytic Capacitors, Intermittent problems are real tricky to fix, If ya handy you could try opening it up and having a squiz, look for any loose connections or "Swollen" Capacitors see if all the "Lights" are on etc, try gently "Tapping" around maybe it's a "Dry Joint" but my money is on the PSU. If ya can see a problem say Faulty Electro's replace with the same or better Temperature rating ... Good luck
Posted on Jul 30, 2007
How to turn my sony tv back on
You are experiencing intermittent power supply failure
May 05, 2013 | Sony BRAVIA Televison & Video
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
I have a Gate SX2800-01, and when I press the power button, sometimes it turns on fine, but most of the time it the power button flashes once, and then the cpu boots up, but the screen doesn't get any...
all you need to do is update the drivers for monitor or the monitor is going out just go your hardware and click on the monitor then update drivers it will tell you if it is working properly
Jul 07, 2011 | Gateway SX2800-01 PC Desktop
I have a Acer X203H Monitor. Everything is connected I've checked a million times. When my computer turns on it displays fine on the monitor, but the first or sometimes second time the computer goes to...
I would try this monitor with another PC first to verify that it is not PC problem.
Most common failures in the monitors are due to bad caps in the power supply/inverter board, we want to find out first if it is the monitor or the PC problem.
See examples of failed ACER due to bad caps here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Acer X203H Monitor
Monitor will not turn on
try connecting it to another PC and check
Jan 18, 2010 | Computers & Internet
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
Turns off and on by itself
Ok so its connected to your pc?
check settings on the monitor itself [if you'restill able to do that]
disconnect all your usb devices restart your computer and try again.
Is it in a cold room ? that might be the problem.
Is it in the same powerbar as your computer ?
I'm not sure but if your power outlet where you connect it is simply looped to the rest that are in use [lazy electrician] then it might turn off because a power shortage.
Good luck
Dec 21, 2007 | Acer 19" LCD Monitor
Sony GDM-F500R (G1 Chassis) has trouble turning on
sometimes relay contacts get "sticky" from arc oxide corrosion whenever enough electricity is passed from metal to metal...in a perfect mechanical relay, the relay would be sealed in a vacuum. Try swapping relays to transfer the problem. If you can transfer it, you found the bad relay. I actually have disassembled relays and polished their contacts with great success.
Nov 13, 2007 | Sony GDM F500R Monitor
The screen seems dead
Hi, normally monitors have an indicator light that lites up when power is applied. This changes color or another lites up when it receives video signal from the computer. If no light then most likely defective monitor. Possibly the only way to positively check is to replace it with another known good monitor and connect to the PC. Power up and there should be a display. If there is then the 1st monitor is defective, if still nothing then it is the PC that is defective. It might also be worth to check/replace the power cord and/or video cable if applicable. Hopes this works out for you. Good luck and post again how things turn up.
Aug 05, 2007 | SGI Silicon Graphics GDM 4011P 20" CRT...
SGI Silicon Graphics GDM 4011P 20" CRT Monitor Logo
66 people viewed this question
Top SGI Silicon Graphics Computers & Internet Experts
David Payne
David Payne
Are you a SGI Silicon Graphics Computer and Internet Expert? Answer questions, earn points and help others
