Question about Kenmore 15899 Built-in Dishwasher
Model 665 15899 builtin dishwasher doesn't clean well
Fine food particles are left on glasses and inside the unit walls (upper portion) we've tried large and small loads, dry and gel soaps, extra soap, adding more crystal rinse, is there a filter or drain that can be cleaned?
    Sergeant:
  • 250 Answers
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.Step 6. Remove the screws holding the valve to the dishwasher frame.Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly. Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle. Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged. Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary. Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit. Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Jan 31, 2009
    Sergeant:
  • 326 Answers
  • 837 Answers
Buy some CLR and run it through a full heavy cycle with about 1/4 cup in the dishwasher and fill your soap (pre & wash) compartments
  • 679 Answers
Yes there is filter that needs to be cleaned
  • rockfixya
    rockfixya Jan 31, 2009
    check this and let me know, for further assistance.
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Asko dishwasher D5233 -- food particles left on glasses after wash
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Apr 20, 2014 | Asko Dishwashers
Ldf7932st cleaning problem
clean the filter in the bottom of the washer. refer to your use and care manual
Apr 29, 2012 | LG LDF7932ST Builtin Dishwasher
Dishwasher shoots food particles inside glasses and dries them on.
Aren't you rinsing the food off your dishes, before you put them in the dishwasher? You are going to need to pull the entire dishwasher out of the counter and tip it on its side. Then you will need to clean the trap before the sump pump. Then flush the unit and clean it out again.
Jul 07, 2011 | Dishwashers
The dishes/glasses on the top shelf are not getting clean
Here is a link to a procedure I put together to clean out your pump. A plugged up sump is the most common reason for poor washing on the upper rack.
Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 30, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665 15899 dishwasher won't clean
Make sure the filter inside the dishwasher is cleaned out and read about my advice for dishwashers for more tips.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Jan 31, 2009 | Kenmore 15899 Built-in Dishwasher
Dishwasher is leaving food particles everywhere
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 03, 2006 | Admiral 24 in. DWUA800AA Built-in...
Kenmore 15899 Built-in Dishwasher Logo
55 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
