Question about Pride New Mobility Rally 4 Wheel Scooter
Faulty speed adjustment control
Information on how to disassemble in order to replace same
  • Pride Master
  • 1,271 Answers
Can you please tell me the Brand and model ?
Posted on Jun 13, 2009
My treadmill not running after 7 seconds diplay shows L5
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It is common to see this error as and L5 error, but it is actually an LS error. The following information will define this error and give you the possible solutions to fix this issue.
LS Error with No Belt Movement on Landice Series Treadmills
LS Error on Landice L-Series Treadmills with No Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
Corrective Action A) Enter Open Loop Speed mode and set treadmill speed to confirm proper line voltage to pwm board and that the green BELTSW light is lit on the relay board. Replace upper display board or relay board if necessary.
B) Inspect speed control wiring and correct wiring if necessary:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
C) Inspect motor control wiring, checking wires from motor to A+ and A-. Correct wiring if necessary.
D) Inspect motor brushes verifying brushes slide freely, are at least 3/8" long, are curved and have no burns or cracks. Also check the brush springs and verify that the brush copper wire is not burned or broken. Replace both motor brushes if necessary.
E) Inspect motor turns and is not seized up or has a broken shaft. Replace motor if necessary. Also verify at least 90VDC present from the black (A+) wire and white (A-) wire from the pwm board to the drive motor. If voltage is present, replace pwm/relay combo board. If no voltage present, replace drive motor.
Details about LS Error on Landice Series Treadmills with Belt Movement
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
Correct speed control wiring if necessary.
Oct 13, 2015 | Exercise & Fitness
Motor noise
It has been my experience with knocking kitchenaid is one of three reasons all related to the speed control of the mixer1 speed control board adjust speed screws2 speed Phase control board, needs replacing3 The motor governor behind the speed control board needs replacing
Speed board = $9.00Phase Board = $20.00Governor = $10.00Your time + one week for ordered parts asnd one hour to remove and replace.
all work is performed at the rear of the mixer and you need only a phillips #2 screwdriver, a pair of needle nose pliers, an 11/32 open end wrench (you will need this to adjust your speed control board after new install) and that's it. easy work all remove and replace. Oh! make sure that you pit some thermal paste behind the phase control board to avoid burn out.
But!!! before you buy parts and do all that, try adjusting the speed contol board first. Go here for a parts list for your model.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KV25G0X&siteCd=KAD&userType=Servicer
then go here for instructions on tuning the mixer speed.
http://www.youtube.com/watch?v=pUo_ZU5xh3o
if after you tune it you still get the knocking then use the parts list to order parts. two good parts sources are goodmans.com and mendingshed,com, they are reliable and have the parts in stock.
Aug 26, 2012 | KitchenAid KV25G0X Stand Mixer
I have a nordic track 4100i treadmill.
1) Faulty sensor speed try to adjust it face to face magneto motor
2)Sensor speed try to tight the connector very well.
3) Replace if neceesary.4) Main motor faulty or burn. Test 115vac for input measure without load fore easy running.
5) Test the main motor controller board for 115vac input and output for +5VCD,
6) Adjust the deck bel for 2-3" for lift max.
7)Lubricate the deck bel.
8) Test the transformer for input and secondary voltage.
See the block diagram for illustration how the main motor controller has 90% aprox of function of any treadmills.
sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 20, 2011 | Nordic Track Nordictrack Apex 4100i...
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Oct 20, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Speed control lever stuck or locked. How do I unlock it?
Hi BROOKLYNX. To answer you primary question, no there is no special speed control knob lock that you?ve inadvertently triggered. OK, so without a lock why?s your speed control knob stuck? It most likely that something broken inside your mixer to lock it into position. I wouldn?t continue to operate your machine as you are doing. It?s not good for the electric motor, the electric cord or the plug. It would be better to determine the root cause of your control knob?s obstinacy. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. You?ll want to focus on part #s 2, 3, 4, 5, and 6, which is our speed control assembly. Check to see if something isn?t blocking you?re the movement of #3. You should be able to determine if something has broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid K45SS Classic Stand Mixer
The speed selector switch will not stay "off'. does not catch. any movement of the mixer causes spring to pull lever out of the off position. Turned on when I was changing mixer tool catching my hand.
Hi, BLSMLK1, Sorry to hear about your KA mixer. It should never ‘bite’ the hand that feeds it, but maybe until you get your speed selector switch fixed or replaced, unplug prior to switching any mixing blades, whisker or dough hook. Power machines can break bones, or worse... From the symptoms you describe, it seems to me that the selector lever attachment screw has loosened, and possibly the speed detents have been damaged so they don’t engage the selector lever and the spring will win every time.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KSM90P, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus Nos. 1, 2, 3, 4, which are Pivot screw, Spring washer, Switch lever and stud, and Control plate spring respectively. Disassemble your mixer to the point of accessing your speed selector assembly, and inspect the pivot screw to see if it hasn’t worked itself loose over time. That’s the simplest thing to fix. If loose, tighten. Inspect the rest of the assembly to determine if something else hasn’t broken or gotten out of alignment. If something has broken, you can order replacement parts and install them yourself.
While your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If this solution has been helpful, please rate it, thanks! – hslincoln
Nov 26, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Speed control faulty , only runs on 8 to10 speed.
Hi, RYLAND. You’ve assessed the problem, now you need to disassemble your mixer and replace the faulty control assembly. Unfortunately since you did not provide any model information, I kind of limited in what I can provide you for an answer, so I’ll give you a ball park answer. You suspect your problem has to do with the speed control assembly or governor assembly inside your mixer’s head and this is something you can fix this yourself.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number and select a file listed under Parts List. Some models will have multiple files. Download one and check to ensure it matches your mixer model. If it doesn’t download another until you find the correct manual.
Depending on your model, locate the Governor Assembly and Control Plate Assembly Turn on the pgs. titled – Motor Control Parts, or Control Assembly on pgs. titled – Case, Gearing and Planetary Unit. The illustrations provide an exploded view for the disassembly and reassembly of your mixer’s components, along with all the parts.
First inspect around the controller assembly to ensure all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Nov 21, 2009 | Food Mixers
Question regarding KitchAid mixer, Model K45ss. excessive noise.
Maeveda, Congratulations on your 30 year old KA mixer! Was it a wedding present? Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
Nov 02, 2009 | KitchenAid K45SS Classic Stand Mixer
Landice won't start, it gives a L 5 error. I already replaced both chip boards. but the light on the board closest to the motor does not come on! Not sure if I got a faulty board? Is there any information...
Oct 14, 2009 | Landice L 7 Club Cardio Trainer Treadmill
Pride New Mobility Rally 4 Wheel Scooter Logo
116 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
