Question about Averatec 3200 Notebook
Battery I charge the battery up and the icon reads battery power remaining o and battery light flash orange .But computer will run for 2 hours after unplug from charger? bill
  • 2,229 Answers
Is this an OEM battery (did it come with the computer)? Even if it did, your circuit that reads the battery charge is apparently not functioning. This could be as simple as cleaning the battery terminals and the corresponding terminals on the computer.
Otherwise, you should probably replace the battery as you have no reliable way to gauge the status of the charge.
Posted on Feb 06, 2009
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell inspiron b130 power problem
try running with battery out it should still work as long as it is pluged to a/c
Feb 18, 2009 | Dell Inspiron B130 Notebook
When I try to charge the battery the light just flashes and the charger does not work.
Hi, I had the same problem!
Had not used my camera for a while so I decided to but my battery on charge, once in the charger the orange light just kept flashing so I left this in "flashing" for a good hour or so.
I removed it and then replaced it, and it was still flashing so I decided to get a new battery (£40!).
I put the new battery on charge over night and it charged great, so I thought I would re-try charging my old one before I sent it away for recycle, and guess what the orange light stopped ON and it was charging!
Not sure what happened here, it was either charge the old for an hour with light flashing and then remove and leave over night and re-try OR insert a good battery to re-set the charger?
But I now have 2 good batteries.
Hope this helps :)
Apr 23, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Averatec 3200 Notebook Logo
100 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
