Question about IBM ThinkPad R51 Notebook
IBM r51 battery won't charge. How to confirm if battery is good?
  • 31 Answers
Most batteries have a indicator lights ion the battery. Look for a small button. When the button is depressed indicator lights should light up. If the battery is dead they will blink or not light up. Hope this helps.
If the indicator lights work you may have to fully discharge the battery and recharge at least twice to bring the battery back to life.
All notebook batteries need to be regularly discharged and recharged or they will fail.
Posted on Feb 01, 2009
    Sergeant:
    Champion:
  • 289 Answers
Once u hold the battery and see it has to be cool,if not it as to be changed it has become old.
thanks
Posted on Jan 31, 2009
Window comes up off center, How to put window into center. IBM R51
Sometimes this is caused by a loose video cable. Try taking off the keyboard and gently pull up & then reseat the video cable.
Plz be sure to do this with the machine unplugged AND battery removed.
Good luck
Feb 22, 2013 | IBM ThinkPad R51 Notebook
I have ibm thinkpad r51 laptop. from 1 week i had some problem in my laptop. One day when i m working in it suddenly it turn off........continuously for two days it's not on..............likewise
Hi, there could be a few reasons in which over heating can be major but overall make sure about Over Heating, RAM and Battery gradually. I hope your problem will be solve easily.
Good Luck
Aug 04, 2012 | IBM ThinkPad R51 Notebook
Hello, my IBM Thinkpad R51 gives 4 beeps and won't start up. Can you help me?
1.check ram
2. check processer
3.check display connecter&display
please vote me and rate it
Sep 11, 2011 | IBM ThinkPad R51 Notebook
IBM thinkpad R51 won't boot and the blue screen with unmountable-boot-volume comes up and i cannot bypass it.
Sounds like at least a corrupted OS, but most likely a bad hard drive. I'd try reloading Windows (if that's your OS) first, which should take well under an hour; if reloading takes excessively long, then the system is probably having a hard time formatting the hard drive due to physical bad sectors and the easiest thing would be to replace it. The R51 uses good old ATA/IDE 2.5" 9mm height hard drives, which are not available in most stores any longer, but you can probably get the same size or larger ones on eBay for pretty cheap and replace it yourself. Expect to pay about 50 cents to 75 cents per gigabyte - anything more would be considered tourist prices...
Sep 01, 2011 | IBM ThinkPad R51 Notebook
I have an R51. Sometimes when it is closed it will go into sleep mode and will not wake up after reopened. Also the Access IBM button does not seem to be working.
it maybe caused the system is too heat or the battery is not charge well (your battery is not good)
if the system is too heat you can buy some thermal paste, put it on your processor
if it cause your battery consider to replace it
Jan 14, 2011 | IBM ThinkPad R51 Notebook
4 beeps are coming in R51 IBM notebook we remove memory module but same issue.
Just Remove the Battery and connect the Power Cable.
Try to switch ON the laptop. Please confirm if its working fine now.
Please post your feedback and Vote if the problem resolved as per your satisfaction>
Sep 24, 2010 | IBM ThinkPad R51 Notebook
My IBM R51's battery ran down. Connected the
If it is the first time its happened, has your charger fused/broke.
Is the lead from the power block to the laptop loose??
Jul 09, 2010 | IBM ThinkPad R51 Notebook
My R51 will boot up but will then cycle through windows welcome to desktop and shut down returning to the think pad screen over and over when I use the battery. It doesn't do this when on ac power. I...
The charging device is part of the main motherboard and consists of a six pin SMD chip that controls the voltage and current feeding a switching transistor that feeds the battery to charge it.
I have replaced a few with good results but if you are not and electronics engineer with IR de-soldering equipment, don't try it as you may damage the board.
Aug 26, 2017 | IBM ThinkPad R51 1830 (1830AHU) PC...
How do I change the cmos battery on an IBM r51 laptop
If you turn over the lap top there is two places you can unscrew one is memory, the other is th battery, un screw it and remove battery very careffully also note the way you removed them as you will need to put the new one in the same way.
Good Luck
Apr 11, 2010 | IBM ThinkPad R51 Notebook
Startup Problem
The power socket could be loosing cause this kind problem, must re-solder the socket on PCB of motherboard by component level repair tech.
Nov 27, 2008 | IBM ThinkPad R51 Notebook
IBM ThinkPad R51 Notebook Logo
615 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
