Question about Bosch Nexxt WTMC 3300 Electric Dryer
Bosch nexxt 500 series dryer
My dryer does not heat. It does tumble. Have checked the heater and the reset button. Both are fine. Any ideas? Thanks, Lisa
  • 1 more comment
  • NWWarrior Mar 24, 2008
    I cleaned out all the lint that had built up on the front near motor and the back inside. Still will not heat. I couldn't find coils but may have missed where they are. If it has coils. I noticed some kind of sensor just inside the tumble cage if that is what it is, but I'm not sure if I should bother it. Is there a reset switch and if there is, where is it?
  • Anonymous Mar 22, 2014
    dryer runs but will not dry. No heat. Saw an EO3 code on time.
  • Anonymous Mar 24, 2014
    Running everything well but not hot .
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Posted on Oct 10, 2007
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
I have a Siemens dryer and few days ago it stopped heating, but the drum rotates. The problem was because of a safety reset button that went off. On the Siemens (WT dryer series), it is a red button behind the dryer.
Press the red button and it will restart. I might have started a fire, if not for this safety switch.
A similar reset button must have tripped on the Bosch dryer.
FYI: Remember Bosch and Siemens share their technology.
Posted on Aug 31, 2008
  • 641 Answers
When you say "checked the heater and it fine" did you mean that you checked its resistance by multi-meter? In case of a positive answer- It might be a thermostat issue. Goodluck!
Posted on Jul 30, 2007
  • Dov Dror Aug 03, 2007
    What do you mean by saying "heater and reset buttons, both are fine" ?
I bough a new Bosch 500 series electric dryer and since i had it installed my electric bill went from 200 a month to over 500 a month any suggestions??????????????
Posted on Sep 12, 2008
SOURCE:
My Bosch Nexxt 500 dryer stopped heating. All other functions work fine except heat. I've checked continuity on heating element & overtemp breaker- both OK. What else could be the problem? Fuse?
CONSIDER THIS
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER
Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Dec 14, 2015 | Bosch Nexxt 500 Dryer
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
Bosh 500 series dryer wont heat and rest button wont push in.
then u definately have a problem,and would be better getting a tech to look at it for u
Jan 19, 2014 | Bosch Nexxt 500 Dryer
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
I have a Bosch Nexxt 500 andjust replaced the heating element less than 6 months ago. A week ago it stopped heating up again. Took the back panel off, pushed the reset button but now when I turn it on, the...
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
Aug 16, 2012 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 series dryer
Make sure the vent outside isn't blocked either.
May 21, 2012 | Dryers
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 series electric dryer will not heat up, it just blows cold air. I have removed the back panel and pressed the reset button-nothing changed it still won't heat. The dryer had been in...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Bosch Dryers
Bosch nexxt 500 series dryer runs but stopped heating blows cold air and tumbles but just have no heat.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Hope thes helps you
This help is free...Please find time to rate me.
Jun 28, 2011 | Dryers
Where do I find the reset button on my Bosch Nexxt 500 series dryer? The dryer will run, but no heat is coming out.
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Mar 01, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
4,348 people viewed this question
Top Bosch Dryers Experts
Elie Balas
Tommmix
Level 1 Expert
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
