Question about Apple iPod Photo-60GB Power Hot Sync and Charge Compact Kit w/ Tip Exchange - Gomadic Brand (BCK0010AD)
Not working properly.
Sir i have 60 GB ipod (Apple).When i switch on my ipod the apple logo is coming after that one symbol is coming in that (www.apple.com/support).This is my problem.Please give me solution.
  • geostee Jan 31, 2009
    Sir how can i reset my ipod.Is there any fecilities in the internet.
  • 728 Answers
Try toggling the hold back and foward and putting it back in the off position. Then hold the menu and the center button down simultaneously for about six seconds until the apple logo appears. Then release the buttons and it should work.
Posted on Feb 07, 2009
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
My screen is just white
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod from within itunes.
May 18, 2010 | Apple iPod touch Second Gen (8 GB,...
Ipod frozen
Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps you!
Dec 30, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My Ipod Screen Went White And Now It Wont Turn On, How Do I Fix It?
Dec 05, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
I have an apple ipod 8 gb. It flashes the apple
try holding the menu button and the centre button at the same time for a few seconds until the apple logo shows (this shouldnt be flashing), this should unfreeze the ipod, if not, try plugging it into your computer (install itunes first) see if your computer can find it, if it does open the ipod screen in itunes and look for an ipod update, perform the update (if there is one available) this will reset it to factory default with the newer software, if theres no update try to restore ipod.
If these tricks dont work, im afraid its a trip to the apple store, good luck
Jul 27, 2009 | Apple iPod nano
My Apple iPod Mini won't play or connect to the PC. It displays the charging symbol but isn't recognised by any PC. It also displays the sad face once charged, and then 'do not disconnect' sometimes. I've...
Yes you must do a reset.
Turn the lock switch off.
Hold down the centre button.
Press and hold down menu.
When the Apple logo appears let both buttons go.
Should then work properly.
Jun 28, 2009 | Apple iPod mini 2nd generation MP3 Player
My ipod screen froze with an apple symbol on the screen
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
If you want more details, go to:
http://manuals.info.apple.com/en_US/iPod_nano_4th_gen_UserGuide.pdf
Jun 07, 2009 | Apple iPod nano MP3 Player
Ipod 8 gb screen on backlight only no ipod symbol
TRY THIS OUT
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 08, 2009 | Apple iPod MA446LL/A MP3 Player
The apple symbol is stuck on screen
Try connecting your IPod to your computer and try the reset process again
It has to work now
Dec 27, 2008 | Apple iPod nano 8 GB Pink (3rd Generation)...
Apple iPod Photo-60GB Power Hot Sync and Charge Compact Kit w/ Tip Exchange - Gomadic Brand (BCK0010AD) Logo
118 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
