Question about Bosch Classixx WFO 2466 Front Load Washer
Replacing brushes bosch wfl2260 have replaced one side but unable to remove other unless roving motor. how dod you remove motor? thanks
  • Bosch Master
  • 3,463 Answers
Remove rear panel of washer.
Undo 2 screws securing motor to tub.
Pull motor plug from terminal block.
With a screw driver, or similar, lever back motor, keeping hold of it , and remove motor.
Fit new brush.
Please rate my fixya solution.
Thankyou.
Posted on Jan 31, 2009
Bosch rs5 brushes how to replace them
most small wattage electrical motor brushes are held in by a plastic plug with a screw driver slot in the face in the side of the motor casing
with the power disconnected from the wall
remove those plugs and pull out the spring and brush
insert the new brushes
Jun 26, 2017 | Bosch Saws
I have a Bosch WFL 1200 front load washing machine. I need to replace the brushes on the motor. This model only has an "oval" shaped panel at the back. The side and back panels are all one piece and c
ALWAYS disconnect electrics....You need to access the motor from the bottom of machine.as it is a pig to work on if you try to replace the bushes whilst in situ...what I do is empty the machines residual water from drain tube bottom front then remove back.... undo belt .... Then lean the machine at 45degrees to one side and undo the two retaining bolts on the pulley side .the whole motor will slide toward rear of machine but uncouple the electrics block first then remove motor.the brushes are spring loaded and the brass clip slides one way to release?there are plenty of YouTube tutorials on bosch washing machines that show brush replacement.good luck.
Jan 29, 2015 | Bosch Washing Machines
My bosch max wfl2260 gets power, however nothing happens on whichever cycle is selected. the machine takes in water but then just stops. water does not drain unless you select drain on the machine.
hello do you mean the drum is stuck if so check the belt at the back of the washer it might have snaped or come off if this ok then the cause could be the brushes on the motor hope it helps
regards
shaun
Mar 27, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
Drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
Nov 08, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Replacing brushes bosch classixx 1000
Hi ya
The brushes on the machine are located on the motor. The motor for this brand of machine is located on the bottom of the drum. The brushes are in black holders usually but can vary in colour.
The are simply held to the motor with 2 screws each either side.
The best way is to disconnect the pipes from the machine make sures theres no water in the machine and and flip it onto its head i.e. upside down.. use a short handle posi screw drive to remove the brushes from the motor and disconnect the the little wire wire from the end of the brush and remove and replace its that simple
hope that helps
washdoctor
Aug 25, 2008 | Bosch Washing Machines
Bosch Classixx WFO 2466 Front Load Washer Logo
260 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
