Question about BEL 890 Radar Detector
Volume how do i adjust volume on bel 890
Push and hold the PWR button. The volume will go up and down.
Posted on Aug 19, 2007
Solton ms60 keyboard... volume stuck , can't adjust sound once set
There are a number of ways to adjust the volume. 1) Normally a button or keys on the keyboard will adjust the sound volume. You might have to press and hold the FN key or the Alt key then hit the key that adjusts the volume up or down. 2) If you right click on the megaphone at the bottom right near the time you can adjust the volume. If you click Start/Control Panel and look for Sound and Audio Devices you can adjust it there. 4) If you click Start/Programs/Accessories/Entertainment you will see a way to adjust the volume.
Apr 02, 2012 | Computers & Internet
The volume control works to decrease volume but is very difficult when trying to increase volume
This may be an issue with the button itself getting caught on the plastic bezel of the remote. Sometimes this happens when the remote is dropped or the plastic bezel is nicked.
My recommendation is to reprogram the device you are trying to control the volume of. This issue may occur when the incorrect IR code is programmed into the remote. Some IR codes may work intermittently and as rolling codes. Check the program and respond if problems persist.
Jul 27, 2011 | Logitech Harmony 890 LCD Remote Control
How do i adjust voice volume on my jitterbug
The rubber volume button on the outside of the phone adjusts both the ringer volume and the call volume, which is how loud a caller sounds when on a call. If you are not on a call, the volume button will adjust the ringer volume. To adjust the volume of a caller, you must adjust the volume while on that call.
To do this, while looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the call volume level. You may also set the call on Speakerphone mode. If you have the Jitterbug J model, there should be a button labelled "SPKR" on the upper left corner of the keypad.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Nov 19, 2010 | One Touch Jitterbug One-Touch Cellular...
No sound
Hello there :
if you have tried to adjust the volume on the unit and still have no volume then your volume controle know b may be faulty or the speaker inside of the unit may be bad in this case you would have to remove the 4 or 6 screws that hold the 2 halves together and seperate the 2 halves nd inspect the internal wiring to see if there is a wire that has came off of the speaker if so it will need to be soldered back into pla ok?
Hope this is very helpful for you
Best regards MIchael
Feb 24, 2010 | BEL 980 Radar Detector
I am unable to use remote to change tv station or adjust volume.
I would advise you make sure all the buttons are customized. The following link shows how to do this in the software:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9700
If you find they are still not working, try learning each command from the original remote:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Jan 03, 2010 | Logitech Harmony 890 LCD Remote Control
Volume not working. can it be repaired
Unfortunatly, Logitech does not provide repair services for Harmony remotes.
Did you try mapping the command to another button? Or you can create a soft button on the LCD screen for the volume.
Dec 15, 2009 | Logitech Harmony 890 LCD Remote Control
My volume button is not working on my harmony 890. What is the fix?
hope you can do this at home, try to open your remote control, remove all screws, your need thiner, liquid solution, and cotton wool, drop some thiner on cotton wool and wipe it on board, near volume track, and wipe it very gently, make sure not to overflow the cottonwool with thiner, now after doing this close the remote control, and check if it does work. remote controls are very rare in repiars, this is basic way to make it work, hope it work, if not then try to get the second hand 1...wish you best in this process
Oct 26, 2009 | Logitech Harmony 890 LCD Remote Control
Having trouble adjusting the volume
  • 2 ways to adjust the volume:
    • system volume and sound card icon settings:
      • 1. click the volume icon on the system tray and a window will pull up, adjust accordingly
      • 2. click the sound card icon on the system tray and adjust it according as windows pulls up.
Apr 17, 2009 | Computers & Internet
NO SOUND WHEN IM ON MAX VOLUME
There are 3 types of volume: master volume, in-call volume, and multi-media volume. To adjust master volume, press and hold the thumb wheel until the volume control comes up and use the wheel to adjust it. When in a call use the thumb wheel to adjust the in-call volume. Finally, use the thumb wheel to adjust the volume of multi-media while it's playing. One thing to keep in mind, the master volume will override the multi-media volume, so if you can't hear the multi-media after turning it all the way up, you might try raising the master volume fist.
May 21, 2008 | Motorola Mobility Moto Q
BEL 890 Radar Detector Logo
148 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
