Question about Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat
No reverse and lost speed
Works fine at first,then wen goin loses speed and starts jumping and reverses only somtimes
    New Friend:
Hi i have an pride scooter it changers up fine .i go out i can olny get 15min away then it says it flat.i was wondering if anyone no what it could be
Posted on Jul 30, 2013
  • Pride Mobili... Master
  • 1,271 Answers
That could be that you need a new pot for spped control bar, is there any up and down movement ? if yes that could be intermittant
Regards
GeWiz.
Posted on Jun 13, 2009
I have a 2004 ford focus and when I put it in reverse all power is lost like a dead battery. I jump it in neutral and proceed to put it in reverse and it dies and won't start until I jump it again. I...
must have a short in the reverse wire connected to trans. moving shifter causes the short which kills. prob a bare spot on the wire should be on side of trans
Feb 23, 2015 | 2004 Ford Focus
Shifting
I recommend you replace the vehicle speed sensor. The part costs only $20, and is easy to do it yourself. This may not solve the problem, but it would cost much more to fully diagnose the problem.
Jun 21, 2017 | 1999 Cadillac Seville
Chevrolet 2004 engine on but will not move
most likely train miston is goine/check train flude if smail bad it is goin
Jan 30, 2013 | 1994 Chevrolet Camaro
I have an 89 gmc c1500 with a 5.0 litre 5speed trans and the other night when i got home i shut it off and a few mins later was goin to leave again and it would not go into reverse. i have a new clutch and...
It sounds like the shift linkage is badly worn where the gear lever is supported on the shaft. Somtimes there is a plastic bush which ends up wearing out and disintegrating causing the slop you have described. You will need to remove the gear lever assembly from the vehicle to work on it. You should be able to get a replacement bush to repair it.
Oct 05, 2010 | 1989 GMC C1500
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
Transmission slips and reverse stopped working
you need your transmission rebuilt the clutches are slipping
Sep 28, 2009 | 2002 Chevrolet Tahoe
Shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Jan 14, 2009 | Shoprider Sprinter 889B-4 Scooter by
No Power at all.
My suggestion would be to replace the fuel filter, iver had this problem in my vehicles and replacing the fuel filter always seems to fix it
Jul 28, 2008 | 2000 Chevrolet S-10
Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Logo
151 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
