Question about Gateway 505GR PC Desktop
Dvd stuck in unit
Door will not open as there appears to be a dvd stuck in there.
  • 8 Answers
Have you tried the manual release?
Be sure the power is off to the Computer before you do this!
There is a small hole just big enough for a straightened paperclip tofit in. You will want to straighten out a paperclip and slide it asstraight as possible into this hole until you feel some resistance.This is the locking mechanism of the drive. If you continue to applyfirm pressure to the paperclip, the drive should begin to open. It willunlatch, but not fully slide out. You should be able to grab the disktray and pull it open.
Because there is something stuck in there it will take more pressurethan usual to open the drive. I suggest finding an old CD or DVD driveand practicing on it to see where the hole is and how much pressure ittakes to open the drive.
Also, being a gateway, there are a bunch of plastic covers and doors onthe front of the case that may prevent you from seeing the manualrelease hole. You will probably have to take the front panel off thecomputer to find it.
This article may help
http://www.ehow.com/how_4513819_powered-down-computer-cd-drive.html
Hope this helps!
Posted on Jan 31, 2009
2 Suggested Answers
3dmaster
  • 183 Answers
SOURCE: Door stuck open
disconnect all plugs .
remember all plugs where are all there were.
than clean your plyg ,& sockects also,
re-connect all plugs & sockets.
do this with care,it takes time.
THNX
Posted on May 15, 2008
DVD door will not open
Some one is going to have to open the unit up and see what is happening, something jammed or out of position etc.
Nov 06, 2012 | Televison & Video
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
Dvd stuck in unit
Look at the door of the player. There should be a small hole on the door. stick the end of a paper clip into the hole and that should release the door. Kind of how you would open a locked bedroom door lock.
May 15, 2010 | Sony DAV-BC150 System
Have a dvd stuck in the unit. door will not open.
Your going to need to open this u if the door will not open and manually take the dis out by hand, now if you feel you cannot do that then your going to need a tech shop locally do it for you. But its easy you just pop off the screws the cover should slide oven you localte and take the disk out. now once your in there you can see if there was any damage 9 times out of 10 the disc got miss feed.
Good luck if you have any additional questions let me know otherwise please leave your positive feedbakc and ratings.
May 02, 2010 | Bose Lifestyle 38 DVD Home Entertainment...
POWER UP, BOTH DVD &HDD BUTTONS LIGHT, LOADING DOES NOT APPEAR...NO RESPONSE VIA ANY MODE OF COMMUNICATION.
turn off and unplug from power outlet, let sit a few minutes....then plug in power up, check JVC home page on net to see if they have problems with these, could be a disc stuck in unit....if door will not open, take back to where you bought it....I have a Pioneer but I did take the cover off and a DVD was stuck in side, I managed to carefully remove it....it is a slow process as everything is made from plastic
Mar 06, 2010 | JVC DR-MH30S DVD Recorder
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
Door to open dvd seems to be stuck
try turning unit up side down and try again.
Mar 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD stuck in DVR5000
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Nov 19, 2005 | Rio DVR5000 DVD Player
Gateway 505GR PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
