Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Limited water output (saeco vienna superautomatica model year 04)
The machine only dispenses 45 ml water notwithstanding the placement of the cup volume knob. After it dispenses this amount the red light comes on and stays on. If I "reboot" the machine, the red llight goes out but the problem is repeated. I have descaled the machine. If I open it up to try to fix the problem, what should I look for?
Thanks for the assistance - this is a great website.
I had the same issue with the same machine for about the same amount of time. I bought a new pump and a mainenance kit. I found tons of calcium build up inside the boiler, and the bolts to the boiler were rusted to the point where they broke off. The old pump was very noisey and failing to pump water through the clogged boiler. After cleaning out the boiler, replacing the o-rings on everything, and a new pump, the machine is like new.
Posted on Jul 10, 2009
  • 70 Answers
Could be 3 things. Pump, flow meter, or clogged boiler. Pump is a standard ulka pump, flow meters are bought only from saeco as well as boilers. If i had to guess.... If its a vienna black than i'd point to the flowmeter. If you get pressurized water out of the steam wand than its either the flow meter or the boiler. Pointing more towards the flow meter (u shaped white plastic part with in and out tubes.
Posted on Jun 09, 2009
Saeco Vienna Sup018 model. Changed flowmeter and sensor because of water flow problem. Now the unit makes one cup and red light comes on. Turn off machine to reset. Pump work fine, no clogs anywhere. Any...
i had the same problem , you placed the chip with 3 legs on the wrong side turn it over and it will be ok .the writing on the chip of flow meter should face down.
Apr 12, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
What is the difference between a water tank with & without a magnetic float on a saeco Vienna Superautomatica?
The magnet tells the machine that the water is low so you don't run the pump dry and cause it to fail. Some Vienna Supers had them and some didn't.
Jan 01, 2010 | Saeco Vienna SuperAutomatica Coffee...
Only half of a cup of coffee dispensed from Saeco Vienna
the trouble is the pipe that goes to the water tank follow it its hook to a white plastic sensor go in that piece and come out that the level sensor that broken that the first thing and most likely broken if not the circuit board
Apr 04, 2009 | Saeco Magic De Luxe Espresso Machine
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
381 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
