Question about Sanyo DS25390 TV
Sanyo DS25390 Cable Terminal Ripped off
My cable terminal was ripped out of the tv. The actual terminal was connected to a metal box which has a capacitor (so I think) inside. The capacitor itself is the broken item. Now the metal box is connected to the actually tuner via wire. Can I replace the tuner and get a new metal box (with capacitor) and connecting wire, or do I need to replace the capacitor that is broken inside the silver box? I am unsure of the specifications of that capacitor.
  • Ryan Bernier Jul 30, 2007
    Here is a picture.
  • mr frisky Nov 22, 2008
    I have the exact same problem..argh! The picture you took could have
    been the exact same picture for my situation. Does anyone have a
    picture showing the correct connection setup for the capacitor inside
    the metal box housing? I accidentally ripped out the coax connector
    from the back of the TV, and when i looked inside the little metal
    "box", the capacitor was just laying there...i'm not sure how the
    capacitor is supposed to be soldered back inside the little metal box...
  • Sanyo Master
  • 12,061 Answers
I personaly would replace the entire unit, the capacitor is a Ceramic "DC Blocking/Couplng" capacitor, possibly a 0.001uF cap... I should think if ya take it to any component supplier/radio repair shop or the like they would be able to give ya a replacement?
Posted on Jul 31, 2007
SOURCE:
I have a new GE 15306 Mechanical Time Switch and need to wire it up to 2 white and 2 black wires that I had on my old timer. I need more information on the wiring than is on the diagram on cover of metal...
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
GE 15306 is a version of 120Volt Tork 1101 indoor-outdoor timer sold at Home Depot under GE name and number.
You have 2 cables.
One cable comes from Breaker box, and other cable goes to Load (light, fan, motor, pump).
Each cable has black and white wire.
1) Cable from breaker box: Black wire H Hot connects to to terminal L.
Notice there is a metal bridge that connects terminal L and terminal 1.
If metal bridge is missing, use a jumper wire and connect L and 1.
White N Neutral from breaker box connects to terminal X.
2) Cable going to Load:
Black connects to terminal 2
White connects to terminal X.
So both white wires are on terminal X.
Jul 14, 2011 | General Electric GE 56941 24-Hour Outdoor...
How to program with cable using remote
Hello
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
Jan 01, 2011 | Samsung SlimFit TX-T2782 HDTV
My son was moving his sanyo 25" tv in his room and forgot to unhook the cable from the rear of the tv. He ripped the cable nipple out of the rear of the tv, splitting the capacitor connecting to it in the...
Please take this disk capacitor to a commercial electronics store. For example an authorized TV shop, A general electronic supply or an NTE Supply reference catalog. A very good source of info would be your local telephone yellow pages!!!! By far the best place to look. Thanks for asking and good luck!
Jul 03, 2010 | Sanyo DS25390 TV
My 13" 2001 CRT Daewoo TV cable connection got loose
Yes you can buy the connector at radio shack and I do believe it requires a little bit of soldering but not much , the same thing happened to my tv and we fixed it up no problem.
Wayne
Jun 26, 2009 | Sanyo DS25390 TV
I have a Sanyo TV that has a broken cable block.
Take it to any TV repair shop. They'll solder things up so they work. It may not look as cute, but it'll work. Look in the yellow pages. If it's the cable modem you're talking about, contact your provider, they'll replace it at a price.
Jun 11, 2009 | Sanyo DS25390 TV
Ds 25390 tv
I think you will need a modulator with a/v in and channel 3/4 out
Dec 25, 2007 | Sanyo DS25390 TV
Cable connection broke
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
Need Replacement part for cable connector
Satinmsd,
Remove the tuner by de-soldering it and send it in to tip-top and they rebuild them for $27.00... http://www.tiptoptuner.com/
Far less expensive than buying a new one and just as quality.
Bill
Sanyo TV - DS25390
In your model you have to purchase one video RF converter. RF converter contains one video input in yellow colour and two audio input in red and white colour and one cable connector as output. Connect the dvd output to this converter and tune the tv program in which place you receive dvd signal.
Aug 26, 2007 | Sanyo DS25390 TV
Televison & Video Logo
110 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
