Question about Canon PIXMA MP600 all-In-One InkJet Printer
Paper stuck? error message 6A00, some ink jets need backup
4 weeks trying to fix paper. Can't gt it open to look for left over paper. Husband has alzhiemers and is home. Need to clear this up.
Yesterday the error message came up.
I have not been able to get back and reorder the low inks as have done before.
Exhausted
  • 4,041 Answers
Hi
Try this
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
What is error 6A00 message on cannon MP830
Print Head Cartridge is locking, how to fix:
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
10. Plugged power back on.
Jun 18, 2012 | Office Equipment & Supplies
Cannon MP830 when turned on, screen displays error 6A00
How to resolve 6A00:
Jun 18, 2012 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp830 shows me a error code 6A00 on the mini screen what must i do to fix this
Try this:
If It can not bring it to service center
May 24, 2011 | Canon MP830 All-In-One Printer
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Error code 6A00 shut down machine. How do you fix it?
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Errow message 6A00 the ink jets will not move manually to the left. I can not see the sponges that I have read about. Thanks! Debra
Hi there
This could clean it up for you.
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Feb 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Alarm blinking, I restrated printer, replaced ink jet and cleared printing queue but still error code comes up and won't work . error 6A00.
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 12, 2009 | Canon Pixma iP4500 InkJet Printer
Error Code 6A00 on Canon MP830
try this 1. Opening the cover and wait for ink carriage to center 2. Pull out power cord 3. Pushed carriage to far left (should slide easily) 4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear. 5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel 6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white. 7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down 8. Slided carriage back to original position 9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Jun 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Printer says error code 6A00 What do i do?
Try this especially if the printer had not been used for some time.
Switch it off, open the lid and manually (GENTLY!)slide the cartridge-tray to the left. Then you can see if a piece of paper or ink stucks it. Gently degunk the base pad with a little isopropyl alcohol on a Q-tip and ease the mechanism back.
Dec 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
